Got my track spec (uncomplied) DR30 that i have no time for anymore..
Rebuilt less than 2000kms ago with..
Forged pistons
Machined/Balanced bottom end
Light head work
To4E with external gate and screamer
Big injectors
Motec ECU
Made 200kws on its first tune since rebuild (has more in it)
Fresh Gearbox
Extreme Heavy Duty Puck Clutch
Locked R200
Hydraulic Handbrake
BRIDE drivers seat
Stripped interior (sound deadening, Carpet Etc)
No back seat
6 point bolt in cage
17x8.5 in mesh rims with good tread.
Or random 15/16's depending..
Plenty more but i can't think of anything else at the moment
Email: [email protected] for more info/ pics
Looking for around the $8/9K mark
Only reason for selling i bought a GTR and work has the better of me time wise at the moment.
https://www.sau.com.au/forums/topic/319013-dr30/
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
