Rb26 Stock Rods With Arp Bolts Or Eagle H-beam Rods?
i wouldnd go that far, here is a Supra on E85 putting down 1147 rwhp/822lbs/ft(1115Nm) @ 2.8 bar boost with eagle rods
on that day they did about 50 pulls. 30 of them were in the 1000whp+ area.
going to quote my post again 1147 rwhp(855 kw) with Eagle rods in a Supra(2JZ-GTE) so they are not rubbish it seems
Pauter rods have held up well, at least in the Supra world
I would think the Carillo H-Beam Rods are the strongest ones you can find.
Multiple 1400+whp(1000+kw) Supras that use them
like SW with is record setting 6speed manual Supra 7.91 @ 189 mph in the 1/4 mile and 246.2 mph(396.2 kph) in a standing mile. Stock gearbox, stock axels and stock rear/TRD LSD, IRS btw
Amit Bhaktas Supra 1722 whp( 1284 kw) and it did 243.67 mph(392 kph) in a standing mile
Tommy bahn / ABM Supra has done 247.7 mph(398.6 kph) in a standing mile
WOTM// Ryan Woon used them also in his 6spd Supra [email protected]
Darin @ Titan used them when he was going 8.38@174mph
and i could go on and on since all the quickest/fastest Supras seem to use Carillo H beam ......Carillo H beam = the way to go if you want the strongest i think.
  • Replies 43
Some of the supra guys had problems with the Carrillo rods but this was quite a while ago, they did bend a couple under high boost. Carrillo changed something on their 2J rods which seems to have resolved the issue. You'll see that they have put HD in their product line for the 2Z series rods.
I fitted some Nitto rods in a 30 last week and they definately look strong. Slightly heavier than the Argos though. The argos use a groove in the side to allow some oil to get thrown in the direction of the piston and the Pauter rods use 2 grooves in the side for the same thing but they can also be ordered with a oil hole right thru the rod to the pin. I personally think the Nitto rods are one of the best on the market and would recommend them to anyone building a tough rb30. The little end on these is undersized so they can be honed to suit the pin being used unlike some rods on the market that are to loose right from the word go.
Smiley was building engines while most on here were still getting lunch from their mothers tit and seen more rods than the average punter...looks like he's impressed too.
Edited by Swiper the Fox
 Share
    • Put up photos of the crimps you're planning to use. Let us critique them 😛 But seriously post them up before you use them
    • I want to see crimps better than what would be minimum standard for the now dated International Space Station. Street GT-Rs now have better wiring than Space X Falcon Heavies
    • Make sure the radiator fan shroud is on and in good condition. Make sure all the radiator guides are in place. Make sure your intercooler isn't restricting too much airflow to the radiator. Change your coolant out for a 30/70 glycol/water mixture instead of the normal factory recommended 50/50. Make sure your radiator is halfway decent, so not Mishimoto. Make sure your fan clutch is functioning properly. If you have the factory oil/coolant heat exchanger a larger oil cooler or better ducting can help take the load off the cooling system. If your tune pulls out way too much timing to achieve the power figures that it does and the pressure peak is happening well after TDC turn down the boost. Less thermal efficiency means more of that heat is going into your coolant and engine oil instead of the wheels. E85 would likely help a lot in this situation as it naturally has more water dissolved in it and the combustion of alcohol releases a lot more water than gasoline. I would also recommend doing some temperature logging of various fluid temperatures. Rear differential, transmission, transfer case, front differential, power steering fluid. Gear oil shouldn't exceed ~140C. If it is getting too close for comfort you might need to consider some method of cooling it off better. Keep in mind that these systems are kind of all interconnected. The oil pan holds the front diff for example and keeping the engine oil cool will help cool the front diff in turn.
    • Ok, I've just ordered the high amp flanged kit from EFI Hardware.  Once it's installed, I'll go for progressively longer/harder drives and I'll check the temp of the terminals with the heat gun.  If there are any issues with temp, I'll drop in the Walbro 460 which should draw about 5 less amps and I'll repeat the process checking temps.  Also I'll make sure to take some high res photos of my crimps this time =P
    • Yeah that and I should it was 2 pin as well but it’s in the right spot
