hey guys seam to be having a bit of trouble with my diff, and i am after advice..
what has been happening over the last 6 or so months is the diff seams to be getting very tight/clunky
when turning at a T intersection when i have just taken my foot of the clutch.
now it is starting to do this at higher speeds which it never used to do (40kph thru a roundabout)
can anyone tell me what is actually happening as it is just the stock diff, and it never used to do it.
if i need to look at replacing things, what should i be looking for, jut shimming, rebuilding, aftermarket?
i just want it to stop clunking :P
also my friend mentioned to me that i should stop driving it incase it locks up, will it actually lock up, and if it does
what will happen? in anycase i think it will need to see a mechanic, as its my daily driver.
any advice would go a long way, thanks.
https://www.sau.com.au/forums/topic/319021-what-will-happen-when-it-locks/
And to answer the questions about the locking
I got a nismo 2 way diff which is always locked. Let's say you are on a bend accelerating gently and you back off the accelerator I feel the back end kick out. Worst thing in your case is that you don't know when it's going to lock. Pretty much just have to worry about understeer and the back end coming out when it locks
if it locks it wont just kick out he will need a lot of speed it will just be even clunkier..
agree with you though doesnt sound like a stock diff cos they just single spin most of the time haha.. get it looked at man best thing to do
Sounds like you may have a decent aftermarket diff and is LONG overdue for an oil change.
I know with my Kaaz diff, i need to change the oil every 10,000-15,000km. As the oil gets older, the diff gets clunkier and noisier.
I have driven a 33 with a welded diff, it's not that bad/dangerous; you just need to keep it in mind on wet roads and take it a little easier.
You guys might be on to something with the aftermarket diff. The car did have after market greddy suspension, i have it booked into the mech next monday to have the drivers side ball joint replaced, hopefully the diff just needs some new oil. Will the mechanic have to take the housing of to have a look, and will there be any special markings or stamps on afyermarket diffs? (so the stock diff would never "clunk" in a tight corner right?)
since we on the topic of diffs.
Anyone got advice with driving with a 2 way diff on the street? thinking of getting one in the future and i like to do alot of research before hand!
and i'm trying to get into drift hence the 2 way
nothose pictures dont help you need to pull the rear housing of the diff to check what sort of centre you have and it def sounds like a 1.5way 2ways are usually really noisy make sure your mechanic dosnt try to rip you and replace the whole assembly as for driving with a 2 way take extra care in the wet when down changing gears sometimes its like pulling the handbrake on if your doing a lot of street driving maybe stick with a 1.5 way
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
