  • 1 month later...
  • Replies 105
Hi Guys, sorry for the delay on the reply.
After multiple attempts to get the nav conversion going i've been offered a refund by the supplier/installer who just can't seem to quite get the thing going so i'm going back to the video out option from my samsung mobile which works nicely anyway. Gives both video and audio directions from the factory screen and speakers system but obviously no touchscreen on the headunit. If anyone wants to see the phone approach just let me know and i'll get some photos uploaded.
Thanks
Thanks
Id love to see it. Wish this worked with the iphone
Hi Scarf
There is an interesting thread presently running that uses an IPhone 4
see:
Video In Motion Solution, Cheapskate - DIY Job for those with iPhones
Its for a V35 - but I wonder if it could work on a V36 with the av input plugs and the V36 JDM TV??
Peter Melb.
Hi Scarf
see:
Peter Melb.
Ive just downloaded those apps, and I'll give it a go tonight. Cheers
  • 1 month later...
nope.
4 figure sum though and I won't elaborate on which side either.
that is just unfortunate
is there a solution to get at least the tv working? i can survive on my phone gps like i have in the past, just not the holistic solution for a new car that i would've liked, oh well.
thanks
without money - not really.
that car is unique to japan and as such the systems are as well. to get it working outside that country is a full refit and that also counts for the TV side of things.
that could work if th car was sitting still.
the thing people are not getting with this car is the complexity of it. you can't simply bang a box into it. it all has to be linked in properly.
OK I have a victim :P
red 370 SP with a touch screen. WA customer.
stay tuned for a rework of it. I'm probably going to dump the HD as well.
anyone keen for a fiddle.
processor is a hitach SH4.
OK:
this is a NON NAVI car I am working on. now the unit that is in it IS IDENTICAL to the local 370Z unit. plugs,wiring,screen - everything!
for those that want a easy way out of the radio and lack of navi issues - 370Z/G37 panel IS THE WAY TO DO IT!
firmware would stop it. already been down this path with 3 toyota units. it will load it speak in english but not load the maps or anything else.
the only reason I mentioned the non navi car is that it uses a jap variant of the 370z item and whilst looking at the USDM and local 370 z manuals its the same unit electrically.
the navi version of the V36 is ENTIRELY different.
Chris,
Could you list which version is possible to convert or are you still playing with car from WA? What functionality it would get? Also what is your estimates in $$?
I take non-navi doesn't have any cameras and dash buttons layout is different so can identify easily?
Thanks.
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
