Hi guys,
I apologize for this thread being so close to Superlap, the delay was out of my hands and will definatly not happen next time around.
Anyway, enough about that, Superlap is getting close and we have a deal to get discount tickets to the event.
If you dont know what Superlap is, its a time attack based meeting at Eastern Creek. Many international teams are coming over, so this years one should be a real blast to watch!!! A few SAU members will be in there, of course the most well known is this R34;
Also, more info can be found at; http://www.superlap.com.au/
Prepaid ticket prices;
Saturday only, $35 ($40rrp)
Two day pass, $50 ($60rrp) <---This one is the best if you can take Friday off work, open testing is on Friday
To get tickets its really easy, here's the steps;
1. Deposit money into SAUNSW bank account (details below)
2. Post up in this thread, your full name and date of deposit then PM ME YOUR POSTAL ADDRESS FOR WHERE YOU WANT THE TICKETS TO GO!!!
3. Tickets will mailed to buyers on Monday the 17th
Bank details are;
Bank - NAB
Branch - Marrickville
Account name - Skylines Australia NSW
BSB - 082 356
Account number - 546 393 766
Reference: PLEASE PUT YOUR FULL NAME AND SAU ID
Cheers guys :P
https://www.sau.com.au/forums/topic/319045-superlap-tickets-discounted/
  • Replies 110
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
