Hi guys,
I apologize for this thread being so close to Superlap, the delay was out of my hands and will definatly not happen next time around.
Anyway, enough about that, Superlap is getting close and we have a deal to get discount tickets to the event.
If you dont know what Superlap is, its a time attack based meeting at Eastern Creek. Many international teams are coming over, so this years one should be a real blast to watch!!! A few SAU members will be in there, of course the most well known is this R34;
Also, more info can be found at; http://www.superlap.com.au/
Prepaid ticket prices;
Saturday only, $35 ($40rrp)
Two day pass, $50 ($60rrp) <---This one is the best if you can take Friday off work, open testing is on Friday
To get tickets its really easy, here's the steps;
1. Deposit money into SAUNSW bank account (details below)
2. Post up in this thread, your full name and date of deposit then PM ME YOUR POSTAL ADDRESS FOR WHERE YOU WANT THE TICKETS TO GO!!!
3. Tickets will mailed to buyers on Monday the 17th
Bank details are;
Bank - NAB
Branch - Marrickville
Account name - Skylines Australia NSW
BSB - 082 356
Account number - 546 393 766
Reference: PLEASE PUT YOUR FULL NAME AND SAU ID
Cheers guys :P
https://www.sau.com.au/forums/topic/319045-superlap-tickets-discounted/
  • Replies 110
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
    • Apexi, though I'm not comfortable with setting the idle, knowing me I'll f**k it up lol.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
