So im planning on buying a r32 vspec II but i dont know how u can tell if its a real vspecII. Besides the bigger rims and Brembo brakes, what else have nissan changed from the normal GTR? Also, on the registration papers would it write VSPECII as well?
thanks
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
