Ok, i've done this before and it worked perfectly!
i've found a few things on my car that i can't work out what they are or do! here is one of them!
Behind my front number plate is a little black box with a wire to it. i can't follow the wire as it goes into the engine bay and into some foam and i can't find where it goes. Could it be to do with my alarm? it appears to have a hole that faces the ground...
There. NOW TELL ME WHAT IT IS!
https://www.sau.com.au/forums/topic/319079-what-is-this/
I don't think i'm right, but all i can think of is it could be something to do with the front numberplate lights????
Or the alarm siren?
it looks too out of place for it to be factory and to do with number plate lights. i will set my alarm off in it's quiet mode and have a listen. that is an idea :) cheers for the reply :)
https://www.sau.com.au/forums/topic/319079-what-is-this/#findComment-5212049
ok, just set my alarm off and it's definitely not the source of the alarm noise...
keep thinking people!
https://www.sau.com.au/forums/topic/319079-what-is-this/#findComment-5212063
If it is hooked up to the alarm, it kind of looks like a shock sensor. No idea why you would mount it there though.
Can you take it off and take a photo of it? It also kind of looks like some sort of water intercooler sprayer.
Edited by PM-R33
https://www.sau.com.au/forums/topic/319079-what-is-this/#findComment-5212127
10 extra hp mystery box?
:( hit the nail on the head
it probably doesn't do anything, no idea why anything else would be mounted there. disconnect it and see if anything changes.
https://www.sau.com.au/forums/topic/319079-what-is-this/#findComment-5213188
Another vote for ambient air temp sensor. I had an R32 before and I remember a thing like that being just under my front bar as well, and some how i found it to be the temp sensor.
I guess if you wanna find out then move it to right near your engine, or put a blow dryer on it while the cars on and see if your temp display on the AC dash display goes up....(no idea what operating range it has so I take no responsibility)...... :(
https://www.sau.com.au/forums/topic/319079-what-is-this/#findComment-5216657
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
