Upgraded so these are spares:
R33 rb25det series 1 standard coil packs - $20ea or $100 posted for all 6
R33 rb25det purple injectors - hi flowed to approx 740cc - $200 posted for all 6 (no fuel rail)
R33 rb25det modified plenum with front mount throttle body - $100 inc. fmic cold side piping, cable bracket, assorted hoses, throttle body (no tps), postage extra.
R32 GTR front guards - rolled/flaired and need some love
$100 - pick up
Ebay 38mm wastegate - $50 posted
Sam 0423 648 114
Gold Coast
https://www.sau.com.au/forums/topic/319098-r33-rb25det-series-1-bits/
does it come with all the cold side piping to the cooler? wat size piping is it and to suit wat size cooler? also how did it go with that manifold performance wise?
All cold side 2.5' Piping, few silicon joiners & throttle body reducer, suits 600X300 fmic, Idle motor hoses. Was making 320rwhp with kkr430.
    • Hi all. So I have my GTR on the lift and have been working on it a few days and yesterday I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
