  • Replies 63
Pete...We haven't even been on a cruise together! I've had to bin mine for 4 odd years whilst finishing the car now im getting it going again..Shed it son and bring it on special occasions!
Pete,
I remember going on a cruise a few years ago with you following me at 1 stage & it sure as hell looked like a lot of fun was happening in my mirror!
Judging by the way people are talking on here I think it should go for a deacent price (ie $15k+) considering the amount of work that has gone into getting it where it is.
It may not be original but it's sure as hell is unique, & that counts for a lot!
I'd be considering it too if I had the money & the garage space....
Can't believe you are considering selling your baby Pete :)
Definitely +1 for a deal with Christian - if he can source you a killer 260RS Stag (why not have RB26DETT GTR power while you're at it) for a swap you would be on easy street methinks. Especially if he could be lucky enough to find one in Bayside Blue (not sure if the 260RS actually came in BB though) .... very nice.
No Bayside available.
Was only 34GT-R, and an expensive option on GT-T's (hence extremely rare).
  • 3 weeks later...
  • 1 month later...
Pete, this thread went from "Thinking about selling" to "For Sale"
Please follow rules like everyone else and post in the correct section............3 pages of turning a blind eye is more than fair enough
sorry sled....... my appolgies...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
