Hey Guys
I have stripped down my rb25det neo motor and slightly melted 2 pistons and seized a comp ring! The car is a r32 set up for drifting and track work and im really happy with the performance it had and how long it lasted(2 and a bit years of thrashing until something leaned it out) Would like to keep this set up so instead of buying a second hand motor I want to rebuild so I know it’s fresh!
The trouble is no one has pistons for a rb25det neo. Im over sizing the block 0.5mm and was going to use acl 86.5mm forged pistons. The only difference I can see is the standard pistons have valve cut outs on the piston head and the acl’s don’t but the dome is more central so looks like the valve would sit on the edge of the dome.
There is not much info on the neo motor so if anyone knows much about them or tried using r33 pistons pls let me know
Cheers
Dan
    • yeah, there's a country that recently started importing Skylines, I blame them.
