Well just installing the gauges you could do yourself for free, it's easy as.
$6000 would include the cost of turbocharging your engine so as to actually make a boost gauge useful.
*EDIT* I am assuming your car is non-turbo considering you posted this in the naturally aspirated section...
Edited by Hanaldo
Yeh my advice would be to install it yourself mate. The hardest part is finding a place in the firewall to feed the wires. It's so easy to do, it really isn't worth paying ~$150-$200 to get someone to do it for you
Edited by Hanaldo
its a turbo.. sorry for posting this in the wrong section!! yeah i have considered doing it myself but just a bit scared, my mate done it to his skyline now all his dash lights are flashing on and off and random times :S but ill read into it some more and if im confident enough then ill do it if not wouldnt mind paying for it to get pro done. thanks heaps for the advice!!
well then make sure you don't let your mate anywhere near your car.
for the water temp gauge you need to make sure you have the temp sender that goes with the gauge. without it it won't work. also you will need an adapter to put it into the radiator hose.
boost gauge is very easy to do. only slightly hard bit is wiring up the lights, but you could always just run all the hose through so the gauge works and then just take it to an auto electrician and them them to sort out the wiring. should only take them a few mins and not cost much at all.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
