Hi, I'm new here and am sorry to bring this up again but I've been through a lot of the past posts and am still confused.
I've just imported a beautiful bayside blue R34 GTR vspec II which is currently in compliance and for insurance I need to know if the factory Nissan immobilizer meets Australian standards detailed here http://www.carsafe.com.au/t_09.html.
Does anyone know if it does?
The car came with a full set of keys that have the red bit on the bottom though I've not tested the immobilizer.
One insurance company does not require the immobilizer to meet the Australian standards (black wiring etc) but only that it has 3 point immobilization. Does anyone know if this is the case?
I would rather not install a new system if it could be avoided but, if it is necessary, do any of the systems integrate with the existing key?
A lot of questions and any help would be appreciated
Thanks
Yes you can integrate an alarm or immobiliser system into the existing remotes. I would recommend the Mongoosee Map 80 which you could have as an immobiliser only or an alarm/immobiliser system.
thanks mate,
that is good news at least.
i will look into it
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
