hey all, my dash lights on my 33 gtst aren't turning on anymore. the problem started because the lower dash compartment under the steering wheel fell off so i was playing around with that and i finally got it back on and now there is no dash lights. i just noticed there is no cable connected to the dimmer but i cant find any cable that could possibly connect to it anyway.
cheers.
https://www.sau.com.au/forums/topic/319271-dash-light-problem/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
