Hey guys, if it helps, I've fitted BC's to a bunch of cars at work now. I've got customers in Soarers, Skylines, Silvias and Subarus that I've fitted BC's to and all are doing very well. All customers are happy with the BC's, great product.
I'll be fitting them to my own Skyline in the not too distant future also.
Anyone interested in buying some Tein type HA jap spec coilovers out of my R33?
  • 2 months later...
Are these BC's Kidney Bashers as the Jap ones in my GTR now are killing me on every bump and the Left rear has a Bad Bang in it so they are Fooked.
Thinking of getting a set of these, mainly do Around Town driving and a bit of Highway on occasions... Are they easy to live with in normal conditions???
Cheers Dave
No issues with mine, have been running them in my stagea daily for 9 months.
I have fairly soft springs fitted, almost stock rates, but the dampening is set firm. They feel great on the road, well worth the money.
As with any coilover it depends on what spring rate you get. You probably want 4fr/3rr or 6fr/4rr for a decent ride.
Has anyone used these coilovers on the track? I am thinking of getting these for track days so I am interested to see what peoples thoughts are for these proposes.
I got a set of the BC ER's (external reservoir) made up for my R32 GTR that see's the track regularly. The standard rates they come with are 12kg front and 10kg rear which I think is way too hard. After liaising with Just Jap, i got the factory to produce a set with 8kg front and 6kg rear. They also revalved them for these spring rates and extended the lengths to ensure they would run at the heights i wanted.
I couldnt be happier with them. On the road i have compression and rebound set to full soft and on the track i have found that about the midpoint on both compression and rebound gives me the best feel. Coupled with the whiteline swaybars front and rear, the car is very neutral now whereas it used to be very understeer dominant. Ive cut my times down at lakeside substantially with these coilovers (and with the swaybars).
I couldnt be more happy with the service from Darron at Just Jap either. I was really impressed with the running around he did for me and the quick response time. I fully recommend these to anyone who are after a good track coilover without compromising too much on the street.
Cool looks like they hold up really well. I've been doing some research on them and there is a lot of good reviews through the other forums. Did it cost more to change the spring rates? If you don't mind how much did it all cost with swaybars as well? I am looking at doing the same thing if I go ahead and buy the BC's. PM me if you like. Cheers
The custom spring rates and setup were the same price which I thought was pretty amazing. There was a lot of extra effort put in to get them made up and at no extra charge to me! I got the swaybars through a seller on here or nissansilvia i think, they are Whiteline adjustable products and were around 210 each from memory.
This is what I was after, My Jap Ohlins that came with the car when I got it are terrible.... Lose my breath on some bumps!
Just ordered with JJ so we will see soon!!!!
Go for it, i went from Tein HAs that were in need of a bit of a rebuild and left my kidney on the side of the road to BC BR series and WOW!! so much nicer to drive my GTR as a daily now
Is it really worth going the ext resovoir BC's or is that just overkill for a daily/occasioanl track use?
If its mainly a streeter, just go the BR series mate. The ER's are great, but are more track oriented (harder). If i was choosing some for a daily, i would be going possibly the BR's with 6kg front, 4kg rear as a max spring rate combo
I went for the 8kg Front and 6kg Rear as per the site and it seem good for the short drive I did today after install.
Compared to what I had in there they are like silk..LOL
Just need to set my heights back to where they were and play with the dampening a little bit.
Edited by Turbo Dave
see i was thinking the same going BR's
iv currently got bilstien's on my gtr, and my rear left knocks like a motherf*ker, but bilstiens are an alright brand, so im thinking of jus overhauling them at pedders or somthing.
    • We are literally just kids stuck in an adult's body with bills and mortgages to pay 🥲
    • Behrman is great quality stuff. My 34 has some serious clouding as well but I’m too nervous to try and replace the glass myself so I haven’t bought them yet.
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
