  • 4 weeks later...
  • 9 months later...
I'll just vouch for BCs again...pulled out the passenger rear for a stripdown and clean after a creaking/groaning coming from that area. Over 3 1/2 years of daily driving and all the components still as good as new, no leaks from shocks, no issues at all. Definitely great stuff for the price of them.
I'm in the same boat, over 5 1/2 years down the track; daily driven as well. BC BR's in my NM35 Stagea.
Coatings are all still perfect, all dust boots, and bushes are perfect.
No leaks, rattles or bangs; and absolutely no degradation of performance.
Way better than I ever expected for the $1200 I spent.
  • 1 month later...
If you want to make your BC's even better, fit them with swift springs. Their springs are more linear, lighter and give longer stroke.
Interesting, where can you get those from?
Also anyone in the know, can you please confirm if BC BR front and rear coils are interchangeable? I currently run 6kg front, 5kg rear and wouldn't mind experimenting with 8kg front, 6kg rear (the standard rates) - can I just swap my current front springs to the rear and buy some 8kg fronts? What's the easiest place to buy online in Aus?
Answering my own question, just checked and my front springs are P/N 62.200.006 and rears 62.220.005. In other words, the fronts are 200mm whereas the rears are 220mm.
Spring diameter is the same and you might be able to get away with the 10% length difference but I'm not sure if I want to risk it... thoughts?
as you can adjust the spring perch at will to accommodate for the extra length and still keep same ride height, I couldn't see anything tragic happening. You might get more spring travel from the extra length? Try it.
  • Like 1
how do the 6kg and the 5kg ones ride and handle on the street? or even on a good bit of twisties? current coilovers in my r32 gtst arent the best and bc looks quite good from this thread
Most people I know get swift springs through Jesse streeter
Thanks Josh. I priced them and they're about twice the price of BC Racing, per spring, landed.
Also Swift only seem to have 60 and 65mm diameter, not 62 which is what my BC's came with.
It all depends on whether you've got enough thread left in the direction you need to wind the spring perch to accommodate the longer springs. If it's there, it's not going to cost you anything to try it.
Thanks guys! I'm pretty sure there's enough thread left, I was mostly concerned about the shock travel with an (occasionally) fully loaded sedan.
Theory is though that with a 20% stiffer spring you'd have less travel over the same bump at the same speed than with the softer spring, right?
I've been very happy with them for almost 3 years now, highly recommended. I'm only considering stiffer because:
  • I did a track day at Sandown earlier this year and there's still a fair bit of body roll, despite the bigger swaybars I'm running
  • I recently got a ride in a Liberty with full remote adjustable Cusco setup, chassis bracing, the lot. It was sweet. I know it's totally apples and oranges but since I don't want to shell out for oranges I might just as well try stiffer springs :)
sounds great, if your car doesnt already have them maybe go for some poly bushings instead of stiffer springs? it would help reduce body roll and retain the good ride quality, plus its a maintenance item that you wont have to replace ever again
2 things - if you're tracking the car def go the 8/6 spring combo, they're a bit harsh on street sometimes but quite liveable. I woyldn't want softer on the track myself.
Also the chassis bracing you mention - i poo-pooed alot of the bracing you see for skylines - until i actually tried it, and now i'm a huge fan. PM me if you would like any further info on that, its already been covered in threads on here.
  • Like 1
I'm running them in a 10/12 combo on my r33 which sees 90% of its life at the track. They feel great on track and are not to stiff for street driving.
They are stiff enough for me to not need to run a thicker sway bar and still not get any roll.
    • It's a fun daydream but personally just looking at OEM implementations of twincharged engines like the recent Volvo engines it makes my head hurt. So, so much complexity compared to even other GDI turbo inline 4s.
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
