Couldn't tell you who it was just a sale guy at justjap. The dampers are inside the coils so I imagine it makes piss all difference to rim clearance. Mounting would be the same I imagine. Call justjap to confirm though but I can't see it being much differece, if any.
The 8/6 are fine on the road for the R33, but it is a larger heavier car.I've got an ADM S15 and was thinking 4/4, 5/4 or something.
Not too such about having equal rate front and back mate.
You don't have much travel on the front as in the rear. You'd have to have the car pretty high (near stock) to not get it to slam on the tire when braking into a corner.
  • 3 weeks later...
hey guys i just put the BC's in my car - BR type on my 34 n/a coupe.
ive got them on the softest setting possible, and its great.
only problem is when the roads were wet yesterday after a long dry period, after turning a corner the tyres would loose traction under acceleration - even very lightly accelerating (i was driving granny spec, since i know roads tend to be quite slippery when it rains after a dry period)
is this somewhat normal? my car has never lost traction so badly or as much as yesterday in the 3 years ive had it so far
Did you lower the car when you put the coilovers in? This will mess up your alignment, which can give you traction issues
yeah the coilovers lowered it massively, it was on stock suspension before
thanks for that mate cleared it up well! I need to pop by bridgestone anyway, one of my studs broke when the wheels were being removed.
thanks again, glad its a somewhat easy fix!
big difference from stock suspension hey, i had some V1's installed set at about 8 from softest. havent lost traction yet (driving dry or wet) on some of the crappiest roads brisbane has to offer.
yeah its a huge difference, brings a smile to my face everytime i go for a drive still haha
thankfully its not too stiff, my kidneys are still intact! I was pretty worried about that.
Will be even better once i get my alignment sorted and the wheel nut fixed up :)
Ill get some pics up once i get time to detail my car ric :)
  • 1 month later...
  • 3 months later...
interesting thread there eightsixboy, thanks!
found this on there
the guy who posted this has since not replied, i wonder how its going for him lol
Couldn't get the link to work; what's the context behind the broken strut?
That would be the weakest part of the damper. I imagine it would happen to most thread adjustable dampers in a crash.
Quite possible; I'm more wondering if they're implying that the coilover breaking caused the car to crash, or this is what they found after a car crashed & decided it was the cause; rather than an effect.
  • 3 weeks later...
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
