Which Way Does The Crank Angle Sensor Go Back In On Rb25 Det Please Help Me Working On It As I Speak
hey guys i just pulled out my cas to have a look at it casue i got missfire probs and i put it back in assuming it only goes one way and i cant get a reading of 10 deg btdc with timing light the cas wont spin anymore anti clockwise
please help me asap cheers
yeah i just put it in how i got it out ! it can only slot in one way right ?
i cant get 10 deg btdc it wont spin anti clockwise anymore
i just did the waterpump on my rb20 is the 25 the same setup with the cas? if so all i did was scribe around the nuts b4 i took it off and the pinion in the middle was half moon only goes one way... also around the cas input it has teeth so it was fairly straight forward...
You need to know what the static timing at idle the ECU is set to deliver. Your tuner might have set it at something out of the ordinary, so it needs to be set at that.
Now... if you know the static idle is 10,15 or 20 degrees and still can't get the correct timing, then the problem is the configuration of the CAS trigger angle, and that trigger will need to be altered.
If you told us what type of ECU it would help.
Also, keep in mind that if you do correct the Trigger settings for the ECU, and get the correct ignition at idle again (15-20BTDC optimal)... then chances are you will have to have your ignition maps fixed too, as altering the main trigger detection angle alters the base calculations for all your ignition maps.
In other words... drive it and potentially have an expensive BANG!
Use caution and seek expert advice if your not sure.
all i done was pulled it out and went to put it back in an then wanted to change the ignition timing to 10 instead of 5 like it was originally
i am runnin a link ecu
i just wana get it back in thr right loction i set the advance limit back to zero on hand controller and i cant get it past 5 the cas wont go anti clock wise anymore please tell me wat to do
cheers
cheers
Is there a half moon key in the camshaft and the CAS?
HI mate, i think i can help
Do you have timing light? always check timing before removal so as to have same performance afterwards.! for next time.
1. re fit cas aligning the half moon carefully ( as they can break off) if it does leave it in the cas.
2. grab timing light connect it to your loop wire near ignition module at top rear of engine above coils.
point in direction of timing marker. If u cannot see markers follow on to next step
3. grab a mate or girlfriend and get them to slowly open the spring face of magnetic pick up (on loop wire) while you are still watching timing marks. you will notice that the marks now align with 5deg markers increments. use your under bonnet stickers as guide for factroy ECU timing.
Aftermarket you will need to get engine warm interface with ECU read what base timing is once car is warm set to to this. you will need to rev engine and hold at 1500 or less to make sure that ecu reads same as timing marks.
3a if having trouble another way to get no1 timing is to remove valley cover and connect timing pick up to centre wire of 3 ( just more hassle on some cars)
i hope this is not to late
cheers
most ecu's have lock timing with 10-15 deg this is used to set timing.
I would prefer if you set everything to way it was.
read what timing the hand controller is saying hope fully it reads 15-20deg
follow the previous post .
im online all day today to help guide you through.
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
