Which Way Does The Crank Angle Sensor Go Back In On Rb25 Det Please Help Me Working On It As I Speak
hey guys i just pulled out my cas to have a look at it casue i got missfire probs and i put it back in assuming it only goes one way and i cant get a reading of 10 deg btdc with timing light the cas wont spin anymore anti clockwise
please help me asap cheers
yeah i just put it in how i got it out ! it can only slot in one way right ?
i cant get 10 deg btdc it wont spin anti clockwise anymore
i just did the waterpump on my rb20 is the 25 the same setup with the cas? if so all i did was scribe around the nuts b4 i took it off and the pinion in the middle was half moon only goes one way... also around the cas input it has teeth so it was fairly straight forward...
You need to know what the static timing at idle the ECU is set to deliver. Your tuner might have set it at something out of the ordinary, so it needs to be set at that.
Now... if you know the static idle is 10,15 or 20 degrees and still can't get the correct timing, then the problem is the configuration of the CAS trigger angle, and that trigger will need to be altered.
If you told us what type of ECU it would help.
Also, keep in mind that if you do correct the Trigger settings for the ECU, and get the correct ignition at idle again (15-20BTDC optimal)... then chances are you will have to have your ignition maps fixed too, as altering the main trigger detection angle alters the base calculations for all your ignition maps.
In other words... drive it and potentially have an expensive BANG!
Use caution and seek expert advice if your not sure.
all i done was pulled it out and went to put it back in an then wanted to change the ignition timing to 10 instead of 5 like it was originally
i am runnin a link ecu
i just wana get it back in thr right loction i set the advance limit back to zero on hand controller and i cant get it past 5 the cas wont go anti clock wise anymore please tell me wat to do
cheers
cheers
Is there a half moon key in the camshaft and the CAS?
HI mate, i think i can help
Do you have timing light? always check timing before removal so as to have same performance afterwards.! for next time.
1. re fit cas aligning the half moon carefully ( as they can break off) if it does leave it in the cas.
2. grab timing light connect it to your loop wire near ignition module at top rear of engine above coils.
point in direction of timing marker. If u cannot see markers follow on to next step
3. grab a mate or girlfriend and get them to slowly open the spring face of magnetic pick up (on loop wire) while you are still watching timing marks. you will notice that the marks now align with 5deg markers increments. use your under bonnet stickers as guide for factroy ECU timing.
Aftermarket you will need to get engine warm interface with ECU read what base timing is once car is warm set to to this. you will need to rev engine and hold at 1500 or less to make sure that ecu reads same as timing marks.
3a if having trouble another way to get no1 timing is to remove valley cover and connect timing pick up to centre wire of 3 ( just more hassle on some cars)
i hope this is not to late
cheers
most ecu's have lock timing with 10-15 deg this is used to set timing.
I would prefer if you set everything to way it was.
read what timing the hand controller is saying hope fully it reads 15-20deg
follow the previous post .
im online all day today to help guide you through.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
