fubar Posted May 4, 2010 Share Posted May 4, 2010 Hey guys Change of plan can't get pistons made up for my car for 8 weeks so not rebuilding atm, im just going to buy a second had neo motor and smash it in for the meen time. My original motor (rb25det neo) has had the vvt disconnected, ant reason for this? and what can i do with the other motor being installed in regards to the vvt swap everthing off the old motor? Apparently in japan it had gtr cams put in but yet to conform it, the cams are out but need to measure the lift... What is the standard lift? Also the injectors are blue and top mount. the only numbers i could get was EBJE100 any idea what they are? couldn't find anything on the net. Cheers Link to comment https://www.sau.com.au/forums/topic/319292-vvt-on-my-current-neo-motor-has-been-disconnected-why/ Share on other sites More sharing options...
Crans Posted May 4, 2010 Share Posted May 4, 2010 if it had rb26 cams in the VCT is not usable Link to comment https://www.sau.com.au/forums/topic/319292-vvt-on-my-current-neo-motor-has-been-disconnected-why/#findComment-5214736 Share on other sites More sharing options...
666DAN Posted May 4, 2010 Share Posted May 4, 2010 standard injectors Link to comment https://www.sau.com.au/forums/topic/319292-vvt-on-my-current-neo-motor-has-been-disconnected-why/#findComment-5214739 Share on other sites More sharing options...
bubba Posted May 5, 2010 Share Posted May 5, 2010 standard injectors +1 Link to comment https://www.sau.com.au/forums/topic/319292-vvt-on-my-current-neo-motor-has-been-disconnected-why/#findComment-5216143 Share on other sites More sharing options...
fubar Posted May 5, 2010 Author Share Posted May 5, 2010 I just measured my cams and i have Inlet 86mm exhaust 82mm That means they are gtr cams Standard neo are inlet 84mm exhaust 87mm Just wondering if i replace the original cams in the second hand motor with the gtr cams and disconnect the vct is that all i have to do to make it work? Link to comment https://www.sau.com.au/forums/topic/319292-vvt-on-my-current-neo-motor-has-been-disconnected-why/#findComment-5217573 Share on other sites More sharing options...
Crans Posted May 6, 2010 Share Posted May 6, 2010 Pretty sure you need to convert the head to run solid lifters. if using GTR cams Link to comment https://www.sau.com.au/forums/topic/319292-vvt-on-my-current-neo-motor-has-been-disconnected-why/#findComment-5218067 Share on other sites More sharing options...
TiTAN Posted May 6, 2010 Share Posted May 6, 2010 Neo motors have solid lifters from factory. Link to comment https://www.sau.com.au/forums/topic/319292-vvt-on-my-current-neo-motor-has-been-disconnected-why/#findComment-5218087 Share on other sites More sharing options...
Crans Posted May 6, 2010 Share Posted May 6, 2010 Oh didn't see the Neo part my bad Link to comment https://www.sau.com.au/forums/topic/319292-vvt-on-my-current-neo-motor-has-been-disconnected-why/#findComment-5218158 Share on other sites More sharing options...
fubar Posted May 6, 2010 Author Share Posted May 6, 2010 Oh didn't see the Neo part my bad lol thats cool, so just disconnect the vct and jam the cams in and it should be all good:) Link to comment https://www.sau.com.au/forums/topic/319292-vvt-on-my-current-neo-motor-has-been-disconnected-why/#findComment-5218360 Share on other sites More sharing options...
fubar Posted May 6, 2010 Author Share Posted May 6, 2010 and a good tune too Link to comment https://www.sau.com.au/forums/topic/319292-vvt-on-my-current-neo-motor-has-been-disconnected-why/#findComment-5218376 Share on other sites More sharing options...
