  • Replies 57
If your car look nice and neat, and you stay away from the plaza on a thursday night you'll be fine.
If you're driving a fish tank with crap hanging off every corner and no springs you'll probably attract more attention than you'd want.
To put things in perspective I've 3 skylines, all of them kinda noisey and fast looking and I've had no troubles. I used to cruise around a lot on thursday nights too. I usually don't do skids around every corner though, and I don't have "P"ull me over plates either.
Not to open up a can or worms or anything, but when my parents where considering on moving to Sydney they where told that anywhere is fine... as long as it is within the the Manly Daily's distribution area. This was around 1993 mind you :yes:
Having been to Penrith an epic 6 or 7 times in my life I can truthfully say that the only bad thing I found about the place is that it is a significant drive for me to get there and back.
i get all my work done by sasha at canak autosports at production place, as for other workshops, hitman is in borec rd, also craved coatings all your powder coating needs there too.
+1 for Canak Autosports. Sasha knows his imports inside out. Does great work too.
Having lived in both cities, I can assure you that in no way is NSW as strict as VIC.... :cool:
True...
nor is policing in this state as covert/clandestine as down south.
Around Penrith, there are some unmarked as well as marked police cars that patrol the straight stretches along Castlereagh Rd & Springwood Rd.
Police also hide sometimes behind bushes in 2 spots along Bells Line Of Road.
I hear from 1-2 workshops that they've had to engineer cars after being defected at night-time after meetups at Panthers' Maccas/KKs/KFC. This all happens as I'm reading a book or Zzzzzzz - and my car is Zzzzzzzzz lol
Wow, I just love Hills people. All snobbery, no class.
Penrith's fine. And there are Japanese imports aplenty. Have been for about five years now. Probably since the last time the Hillsong mob slummed it down there on missionary work. Hallellulah!
You have a great day now.
AMEN BROTHER! lol
although I *think* the hillsong zombies do have a holdout in minchinbury? *shudders*
used to run the vodafone shop in Rouse Hill Town Centre, ugh gimme the riff anyday
As others have said, Canak Autosports near the dick smith powerhouse
Race Solutions/Hitman just behind Nepean Motor Group
Wholesale suspension near the Heartland Holden (got the impression that they're 'love them their V8's types' but they're a good bunch in my experience :blush: )
i work at penrith, nothing much to concern about, the plaza is full of gangas though
There is no emoticon to express the trueness of this statement :)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
