Hows Penrith?
MRSAMO
 Share
AMEN BROTHER! lol
although I *think* the hillsong zombies do have a holdout in minchinbury? *shudders*
used to run the vodafone shop in Rouse Hill Town Centre, ugh gimme the riff anyday
Mate, we are everywhere, even on SAU.
  • Replies 57
Ive noticed an abundant increase in police in and around the penrith area over the last few weeks..
I dun like it!
candy-apple red > battleship grey - matt finish for stealth?
pfft my cars not candy red.. this isnt auto salon!
Engine bay is stealth so im happy, just need some bigger wheels for height/grip and im happy.
Feel like giving those Advans a new home Terry :thumbsup:
p.s. your analogies sometimes confuse me.. maybe your too smart for your own good.
^^^ If I ever come home and find my ADVAN RGs gone, you'll be one of "The Usual Suspects" ;)
Back to Penrith, Tench Reserve along the Nepean River has been a great place to stick a Coffee Club.
Shall see a couple of you there Sunday morning. I'll be sipping my Affagato.
It's also a great place to start a massive cruise.
Is there any fish worth catching in the Nepean River?
Thinking about dropping a line in just near the rail bridge at Emu Plains.
Hiya Aaron,
2X to speak of...
i) carp
ii) 'patience'
The best place is probably across Wiseman's Ferry and about a few km north of Spencer. You'll see some fishing spots there with people parked near bridges + boaties.
The ferry is not 'low-lip-friendly' though, so I'd take an ordinary car.
Good for you, love your work
Kinda makes me wish I got into the whole 'peddling uninspiring generic music that christians will buy' thing :D
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
