Hey guys Up for grabs is my 1988 mazda rx7 series 4 convertible.
- 13b rotary turbo
- 5speed manual
- full 3" or 4" exhaust system
- rebuilt motor
- Microtech MTX-8 Computer
- bigger turbo (not sure contact him for details)
- full body kit Has a few cracks.
- Spooled Diff
I was told it is running 5psi and made 147rwkw on the run-in tune, Motor was built to handle 15-20 pond and with a turn this thing would be alot of fun, and pushing well ova the 200rwkws.
Iv Just got this car my self, b4 going and assumeing anything its a great car nothign wrong with it....... its just not want im looking to drift, (After driving my mates R32)
Looking for about $6500 or swap for a Skyline R32, MUST be Manual.
Car is lLocated in Vic on the west side, Altona Meadows
Cantact me on 0405 183 969
IM after a Skyline that really performs and goes hard......... SO...................
I will also through in my other car for the right Skyline....... as you can see it is an unfinished project, with the body in fantastic condition, Paint is fantastic, Has a full on detailed bay, a lot of time and effort has gone into this car, motor is a 3 litre RB30et built by bresciani Racing, running a hi flow T4 turbo with a Turbosmart 38mm external waste gate, motor has about 5000 to 6000ks since being built. (no recipts) Gearbox is a R33 5 speed, excedy H/D clutch, Detailed Diff, Interior is very very clean, no rips tears or ciggie burns, im a really fussy owner when it came to this car. (most broken plastics were replaced).
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
