Im Currently looking for a Non-Turbo auto R33 and am looking at the cheapst way of getting one. I know that there are some around but that all the best condition ones are in Japan so im probably better off getting one from over there but if i look at it paying for freight and broking and then compliance and all other associated costs it might end up costing the same or even more.
Also being on my P's i know that the cops will try and pick up anything on any car i drive so again there are accosiated problems.
any advice or comments welcome.
https://www.sau.com.au/forums/topic/319335-is-importing-worth-it/
We would absolutely agree. When you are looking at cars around this price range it's much better to look locally, especially for this sort of vehicle which is not really sought after because you can get some real bargains locally sometimes.
Keep in mind that importing a car has set costs regardless of what you buy, so for example if you were given an R33 for free in Japan it would still cost you over $6,500 by the time you get it registered after paying Japanese inland costs (FOB fee), ocean freight, customs clearance, import duty & GST, brokers fees, SEVS compliance, new tyres, roadworthy and registration costs ... and considering there are about a dozen automatic R33's (some turbo and some non-turbo) around already registered in Australia with asking prices around this value then you can certainly get one locally without too much hassle.
100% agree with craig. I reckon by the time you import, pay a broker, pay an exporter in japan their FOB costs, pay entry costs (tax, clearance etc), pay compliance and then get a car registered you are looking at approx $10K for a car you got for free in japan.
my advice to people is basically this. if the car sells for less than $20K in aus then it's not worth importing as the fixed costs of importing are making up to great a portion of your total outlay for the car. example, you buy a car for $1000 in japan. it will cost you about $11K on the road in aus. but it's still a $1,000 car with all the nastiness that that entails.
there are some exceptions to my rule that fall just under the $20K mark, so I'd probably revise it in some cases to $18K or even $15K for some models but a car that sells here for less than $10K I wouldn't even have to think about. it's 100% not worth importing.
iron chef's advice about where to buy is sound too. in sydney before P-plate restrictions people would not even import NA R32s or R33s and you couldn't give one away. once the law changed all of a sudden turbo R33s were worth practically nothing and in many cases an NA R33 (especially a manual) would be worth more than a similar spec and condition turbo model which was nuts. buying one in a state with no such restrictions makes some sense but only if you can really save some decent money as transport, new registration etc will all cost $$$.
I have a mate that may be able to help.
thanks for the advice.
I will start looking local now. though im in no rush and I think any line i get will probs end up as a project car as the car i now have runs really well and my only want for a new one comes from my love of imports. at least its good to know that if your on a budget not to give in to the lure of cheap cars in japan.
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
