Anyone interested in a Sydney Group Buy on Window Tinting ?
I have two cars to get tinted in the very near future and was wondering if anyone else needed to get theirs done too ?
I have a couple of good contacts who can do tinting (not SolarTint or any of those big expensive shops)
If we got 5-8 cars together and went to one of these guys we might be able to get a bit of a discount happening.
Post here if interested.
If no interest in the next week or two, I'll just be going ahead with it.
  • Replies 222
Should be less than $200. I think my Skyline was done for like $180 so if group buy - Maybe $150-$160 - That's just a guess though.
OK That's 3 Cars interested so far:
B-Man - 2 x 4 door sedans
CerealKiller - 1 x 2 door coupe
SW20-GT - 1 x 2 door coupe
Roy - 1 x 2 door coupe
Deserteagle - 1 x 2 door coupe
Endorean - 1 x 2 door coupe
Ultimatepowder - 1 x 4 door sedan
OBaYBe - 1 x 2 door coupe
Duncan - 1 x block of flats
mmmgtir - 1 x 2 door hatch
DJ984 - 1 x 2 door coupe, 2 x 4 door sedans
mzgtst - 1 x 2 door coupe
MrExa - 1 x 4 door wagon (block of flats :P )
fatz - 1 x driftn 2 door coupe
Jimbo2000 - (are you interested Jimbo ??)
cs_180 - 1 x 2 door coupe
raz0$harp - 1 x 2 door coupe, 1 x ppl mover, 1 x 2 door hatch
Mooks - 1 x 2 door coupe
MaTBoy - 1 x 2 door coupe
Merli - 1 x 2 door coupe
TonyGTST - 1 x 2 door coupe
YRLO5S - 1 x Suzuki Cino (what eva that is ??? ;) )
Evil Elmo - 1 x corolla hatch
Mooks (AD) - 1 x 2 door coupe :) :)
Thats - 29 cars. I'll start the negotiations......
Oh - add a post if you are interested !
B-Man...
is it limited 2 skylines, or would they be able to do a commodore? :dons fire retardent suit, stands back and awaits torents of abuse:
im be interestred, however would like to know a firmer figure before commitment...im a student with a slim budget, hence no skyline (...yet...)
I think we should be able to get a price for a 2 door and a price for a 4 door.
I am bringing the Gloria (4 door) and my Dad's Camry (4 door)
So it will not be a prob.
nicknick - are you interested in helping us cost out & manage a group buy ??
Yeah, Id be interested for the stagea, wont arive until april tho. Is there a timeframe, see if you can drag out the end date or even get it as a perm club discount price :P
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
