Anyone interested in a Sydney Group Buy on Window Tinting ?
  • Replies 222
Get your orders in Folks - I have a bout 15 names down so far - and have given dockets out to averyone that has e-mailed me.
If you haven't got your docket, PM me or e-mail me at [email protected]
One and a half weeks until the offer closes folks.
Well, I've booked my two cars in for the Sat 21st Feb. He is coming to me.I actually have one (or two) free time slots at my folks place to get the tint done on this date in the morning, if anyone is interested (in St Ives area).
I know Scott was interested, but I think may be working - And Anthony was too - but I think he will be in Japan.....
I got my car tinted today through this deal, and I have to say the work was top notch, and as far as I can tell, the tint product is excellent as well.
5 stars!!
Thanks Brendan! :) :) :rofl:
edit: I got the 18% cybertint and it's perfect.
5 stars!!
Good Stuff Merli ! ! Can't wait to see it ! :rofl::cheers: And I'm glad you like it - :cheers::) wait till it dries a bit more and it will look even better !
Scott, I got him booked in from 9:00 for 3 cars, so it may work - I'll give him a call and see if he can fit in another car and at what time he might finish the other three, considering 2/3 ar 4 doors.
Hi Guys,
For those of you who have e-mailed me and not got your dockets yet, I apologise, I've been off the air for a while...
I'll get on to this later today or tomorrow.
Cheers,
OK Guys - I think I have updated everyone - I sent 5 e-mails out tonight.
If you have e-mailed me about this offer and I haven't given you a docket number, please e-mail me again or PM me !
FYI - We now have 20 cars booked in for this offer - which is over $3000 worth of business to the tint folks -
This is good business for them and good for us too - Great Prices, Kwality Job !
Remember - offer closes 16th Feb 2004
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
