By Prof_Finesser · Posted
theres the spade signal from the main harness and another eyelet connector that supposed to be on the starter post that comes also from the main harness and then the 12v power from battery aswell -
With some of the left over sound deadening stuff I did the boot in the Bogan Cruise Ship, unsure if will make any noticeable difference, the Minister for War and Finances managed to fall asleep within 5 minutes of hitting a Hwy before anyway There's also a bit of the Carbuilders foam stuff as well, more for something for the spare to sit on/against
What do you mean by "Signal and power from battery to the single post" ? You should only have one 12VDC power cable from battery to stud on the starter and your start signal to the spade for a total of two wires to your starter. Your block also needs to be properly grounded. -
Hello again I'm having an issue with the starter not wanting to crank I have a wiring Specialties harness for r32 and I believe I have it set up right I have the signal and power from the battery going to the single post and then the start spade connector. I made sure I had 12v on the starter post and it does and Im not sure what else to do. I turn the key the only thing I hear is the injectors and fuel pump. Any info is appreciated. I put the install guide link https://drive.google.com/open?id=0B9F33_M_GgENUHJyMnpaRlk1Yzg -
Put up photos of the crimps you're planning to use. Let us critique them 😛 But seriously post them up before you use them
