  • Replies 139
HkS 2835 PRO S kit or a 3076R. Just look at Hamish and Simons set up!
I have been more than happy with my HKS3037 Pro S .68, bit pricey but worth the extra coin imo. Chuck it on E85 and you have yourself over 400rwhp easily.
I got 254kw at 3200rpm with r33 gcg high flow turbo. Im very happy with the response and power i have with this turbo. I only paid $850 for gcg from SAU forums and sold my stock turbo for $300. So only cost me $550. i still retain factory air box and car looks very stealth. Best bang for buck turbo.
I know of people on this forum who have run 12.3s quarters with this power on semi slick street tyres.
Invest in some mickey thompson full race slicks on 15inch chaser rims and a jim berry full monty race clutch and you will run 11s with around 250kw.
Its not always about all out power. Many other factors to consider...
Wow that is a very responsive turbo, the stock turbo only beats it for a split second down low!
Thats interesting you say its not about all out power and the only examples you give are quarter mile times. On the 1/4 mile it IS all about power. Its about your moroso power which is the average of the rpm range you use down the 1/4. So if you spend your time on the 1/4 between 4,000rpm and 7,000rpm then its about the average power between those rpm. So in actual fact for a 1/4 mile race it is about power.
If you were to say street response, circuit racing or drifting then there would be more discussion.
When did the discussion become about bang for buck? The topic is about most responsive turbo to make 275rwkw.
Edited by Harey
Actually its all about power 2 weight ratio.
Harey
If its all about power work this out for me
300kw skyline with street tyres loses everytime to 250kw skyline with full race slicks down the quarter
Its not all about power buddy, its about power, weight, suspension, tyres, tempreture and also driving skill and ability
My apologies to all for drifting from the original thread.
Ps i love you harey
No. you can not beat a 300rwkws skyline on road with good street tyres. I run 10inch Dunlop Potenza in the rear. by end of 3rd you be over a car length behind. Works every time.
Also the more responsive the turbo is the more likely you will wheel spin, and it won't help you getting the torque you need by 3rd.
I guess this thread is about the most responsive 275rwkws. So run 52T 76mm comp in .60 housing with GT30 wheel in .63 rear with ext gate.
Harey
Ps i love you harey
Oooo someones touchy...
Are you upset you bought the wrong turbo?
WTF does weight and temperature have to do with turbo selection??
I will work it out for you, the 250kw has a major advantage of having race slicks.
Why does the 250kw car get slicks and the 300kw car gets street tyres?? Surely both should be the same for an accurate comparison.
With both on race slicks, the 300kw car would slam it everytime in a straight line.
Edited by Harey
Ok so I don't have a 33 but I do currently have an untuned 3071R 0.82 IW (genuine not the cropped version, I made sure of that) on my 34, WHICH IS GOING FOR A TUNE TOMORROW!! So excited :) Basically the same setup as Matt from NIStune, so anticipating 260-280rwkw at 17psi...
Bought the kit from Mick Whittle (Boostn Imports) and can't recommend him enough.
When doing this do you still have the AFM mounted on the intake side? Or in the cooler piping?
If on the intake do you get any problems with reversion?
it's on the intake side attached to the pod in a custom cold air box with CAI
i have had ZERO problems from the first dyno run :)
thaaaaaankyou!
found an old dyno run from a couple of years ago that is kinda relavant...
http://s295.photobucket.com/albums/mm144/h...nt=MOV00074.flv
this is the result after about only 5 runs when we first filled with e85
car now makes ~15rwkw more and comes on a lil earlier
obviously. i don't think that's the issue here, more power (with all other things being equal) will win. hardly ground-breaking stuff.
i think what he was trying to say was that there is more to a quick setup than simply having 11ty billion kw.
If he said that, then I would agree with him. But he didnt.
This thread is about turbo selection.
Edited by Harey
That will be a great setup, I am keen to hear the results. So you mean you have the 5 bolt garrett rear to the exhaust housing?
Guys i love this site and i value everyones knowledge and opinions. SAU forums has ensured that i have made the right decisions in modifying my car with guaranteed results.
And harey, i still love ya mate. You will always have a special place in my heart......
From what i know and have researched my conclusions are as follows
GCG high flow= 254kw with great response for street
HKS GTRS= 250/260kw with best response for street
Garrett gt3071r 5 bolt flange= 265/290kw with good response around 3600 to 3750rpm depending on rear housing
Garrett gt 3076r 5 bolt flange=275/300kw with good response around 3650 to 3800rpm depending on rear housing
Dont waste your money on the 6 bolt garrett series as they are turd.
Hks 3037 and 2835 are great turbos but only for the elite and wealthy
Cheers mate. From my research (and obvious lack of eliteness, wealth and not owning the car back when the yen was at 103 lol) and budget it seemed the perfect choice. Yeah I have the 5 bolt exhaust housing so I had a custom 3.5in dump pipe fabd up for it. I have a feeling my nismo injectors are going to let me down though. But yeah that's for another thread.
No offense - do you know how to read a dyno sheet?
You have 254rwkw @ 6750rpm. Not 3200rpm.
You have ~135rwkw @ 3200rpm
You also have boost control issues.
IMHO the 3071 w genuine housing is definately the best turbo choice for an RB25 in the current climate (2835 being number 1 but cost prohibitive these days)
BUT..........
if i had my time again i would be going a twin scroll 3076 with a 6 boost manifold and GTR plenum
i have had ZERO problems from the first dyno run ;)
Cheer's,
I'll go a full metal intake then with a cold air box then.
Cheer's!
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
