I sourced most of my parts from SAU second hand from good honest people, thats why i love this site..spread the love.
Paid $850 for GCG high flow only 2 years old checked by gcg , sold my stocker for $300 so cost me $550 and installed it my self, piss easy took about 5 hours and everything bolted straight back on. True direct bolton , nothing to change. If i can do it , any one can.
Apexi power fc=$950 second hand SAU
Nismo 550injec=$600 second hand SAU( need injectors to max out turbo potential)
Bosch 040 in tank fuel pump=$50 second hand SAU(needed to meet fuel demands)
Splitfire coils=$450 second hand SAU(needed to run bigger gap on my plugs, went from .7 to 1.1 coppers when i upgraded coils.
JJR return flow coooler=$450 new
3 inch exhaust turbo back full stainless=$650 wreckers
Greddy profec b EBC
Run stock air box.
Tune=$750 unigroup engineering
My set up is begging for a garrett gt3071 or 76r bolton replacement and retune but this exercise will cost me between $2500 to $3000 , to gain an extra 30kw atw on my current set up. The only way i would justify this would be to take a ride in a gtst making 280kw + . If blown away by the difference then i would do it.
For now im at peace with what i have.
Hope i helped.
geez i rang GCG today and was quoted $1900 to highflow my turbo. sorry but just to clarify, you bought the turbo from them 2 years ago, or? maybe they raised the price.
  • Replies 139
He's grabbed it 2nd hand i suspect, lucky grab @ that price. Most people sell them around 1200-1300. :whistling:
Although I don't know what GCG "checked", given you need to pull it apart which means a new cartridge @ around $900-$1100 before you start as its basically rebuilding.
So maybe they just looked at it with their eyes or something tricky...
Lol.
I was fitting a "refurbished" GT35 for a mate last month, it sounded like it had gravel in the bearings. Like you say, if it hasn't got a new core...
I have played with plenty of second hand turbos and not heard it that bad before. Mind you it is still running strong at 370kw.
Bearings aren't supposed to make those kind of noises.
I purchased the turbo from SAU forums for $850 second hand in good conditon. Called michael from GCG and quoted the Job number stamped on turbo and then he gave me the build date. It was only two years old. GCG is in my neighbour hood(condell park), went in and saw michael and he visual inspected turbo, he reckons it looked fine.
I wouldnt spend $1900 high flowing my stocker, just buy a gt3071r or 76r new or second hand.
When you are honest and generous in life things come back to you 10 fold. look after people and people will look after you.
Good quality second hand parts are all over this site and i have been fortunate to deal with good honest people.
Like JC says" love your neighbour as you love your self"
Edited by manuel
ahhh ok $850 second hand, thought i had missed something there hehe, thanks for clearing that up.
yeah well in that case if its gonna cost $1900 to highflow, might aswell cough up another $1100 and go all out with a GT3076R kit. :dry:
i picked up a used 3071 kit for $1500...was gunna get a hiflow but this showed up so took my chances, so far so good.. :D
Although thats said it probably wont make much more power than a good hiflow...maybe less and theres no warranty..
Edited by Arthur T3
Just remember there is a reasonable difference between the two in response, I'd consider a GT28 whatever it is called, the next size down personally.
i picked up a used 3071 kit for $1500...was gunna get a hiflow but this showed up so took my chances, so far so good.. :happy:
it will make it quicker... and that's what you want
i havent driven a laggy turbo car yet, though i think id prefer an epic punch in the balls sort of feeling than a constant fondling sensation, if that makes any sense whatsoever.
lag is ghey... 250rwkw by 3500 is more fun to drive on the street than say 350 by 4500
Hey guys,
With the 3071, which is the best housing to get for an RB25?
I figure that I don't want more than 275kw as it's a 1993 engine with stock internals, so i might as well get the one most responsive to around that figure.
Also, I'm guessing that these take the "normal rb turbo" style dump pipe? I've got a different v band sorta deal on at the moment (that's what the kkr turbo uses), so i'd need to buy one, do i just grab a dump pipe to suit a standard rb turbo or do i need a special garrett fitting? If it's a normal nissan one, i'm guessing that there is no problems using a screamer pipe? Is the 3071 with a different dump fitting a much better turbo? if so, i'd go that option, as I need to purchase a dump pipe either way (as long as it fits up with my front pipe, i'm happy)
Thanks guys :)
3071 with the original style 6 bolt rear Is a bit restrictive Ive been told and will only make around 260kw,Least thats what GCG told me.. whereas garret style rear will make closer to 290kw i think and spools up quicker..
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
