  • Replies 139
Have a read at hypergear's latest update with the ATR43g3. Very reasonable response for 303rwkws. And that is internal gated on a stock standard engine with all factory gears.
That is fairly false, while a good upgrade the majority of results see no where near 300rwkw from the high flows.
Most people see 230-240rwkw from a high flow, dyno results thread to back.
That depends on the type of rear housing that we get to do the high flow as well as the combination of wheel we use refer to customer's driving ability. I've personally tested a .63 PU high flow maxed at 295rwkws, Roller dyno, 98 fuel, tuned by Dr.drift.
How ever the ATR43G3 mentioned is a brand new turbo that is made and proven for 300rwkws application, with 65kws more mid range then the KKR560. Plus controlled run is based on fully standard setup without boost controller or any thing that could advance its original response and power behavior.
How ever the ATR43G3 mentioned is a brand new turbo that is made and proven for 300rwkws application, with 50kws more mid range then the KKR560. Plus controlled run is based on fully standard setup without boost controller or any thing that could advance its original response and power behavior.
yes very good result, these figures are with an aftermarket comp housing, chra and rear housing.... , so as stao said, those are a completely aftermarket turbo... not a highflow
what boost tho? the 3076 will do same power and response times... but less psi needed to make same power.
its not fair? on who? haha as i said ive had both turbos on rb25's so just posting my experiences.
Its not fair on the poor old 3071 :D
I am challenging this statement:
"what boost tho? the 3076 will do same power and response times... but less psi needed to make same power. "
A 3071 will have better response than a 3076 with same rear housing. The 3076 will have more top end power.
true.. i should have been clearer. When we're dealing with the 3071 with a cropped ex wheel and a OP6 style or AVO style rear housing and internal wastegate as opposed to the 60mm garret 4bolt ex gate housing... the 3076 comes out top there.
the 3071 with the same garret 4 bolt rear housing is a different story since it has a 71mm wheel as opposed to 76 it will spool earlier for sure.
just after a rough figure, but 'roughly' what does it cost to highflow and rebuild the rb25 turbos?
Bush bearing combo would be 800-1200
Proper ball bearing unit would be 1600-2200
Many factors involved from who does it, what specs and so on.
Personally, I'd go the ball bearing everytime.
i have a apexi ax53B70, had it tuned the other day and made 240kw on 18psi with 555cc injectors, pfc, z32, 3" exhaust, fmic. but was told i wont get any more out of it. pretty annoyed as i spent just under 2k on it and was told i would see 250 with ease. although i am very happy with the response :D
how much does a 3071 go for?
I got mine from Kudos Motorsports. I wanted the whole kit (dump, lines etc) and theirs was the cheapest i could find
Yeah just had a look, not a bad deal.
ooooo it has an option for the anti-surge compressor housing. did you get that?
Do you have a dyno sheet? I couldnt find one of yours in the dyno thread?
Edited by Harey
no i didn't want to fab up a massive 4" intake pipe, I managed to squeeze my standard one (with metal insert) over the smaller mouth.
dyno sheet is a few weeks away :)
ah yeah fair enough. its also quite a few extra dollars!
If you want the anti surge compressor housing your prob better off getting the 3076 as that comes with one for no extra dollars.
Keen to see the dyno sheet!
Ah yeah didnt think about that. Once you have a 4" intake, the 3" afm will become a restriction and also annoying changing diameters if you did leave it there.
What options are there to remain with a 3" intake. I know simon you will recommend the 4" intake but think about it from a stealth on the street point of view. Is it possible to get an anti surge housing with a 3" intake on a GT30?
I've got an rb20 turbo highflowed by GCG on my rb25, makes full boost almost the same as a standard turbo but it pulls very hard even on 12psi around 200rwkw. Is currently being tuned with gtr injectors and all that jazz, hoping to see 240kw with almost standard response and spool times. For a street car it is all about response.
Only thing I don't like about the turbo is the service from gcg, if anything goes wrong you will be blamed for it and have to fork out for the bill.
Edited by Rolls
I dont understand, how is that related to "R33 Gts-t Turbo Recommendation, most responsive for 275rwkw"
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
