Wrecking R33 Gtst
hi everyone, im wrecking an R33 GTST Skyline. Got both s1 and s2 parts avaliable as it had a s1 front end on it. i have heaps of gear still on the car (fuel tank, diff, cradles, upper and lower arms, power steering pump, swaybars etc and panels) (sorry no photos yet) JUST ASK!!!
#1 R33 GTST Series 1 rear spoiler $50 ono
#2 x2 apexi BOV $60 ono each
#3 series1 headlights $200ono (pair)
#4 Windscreen washer bottle $20
#5 Radiator Fan $70ono
#6 unknown brand cannon, $50ono
#7 set of 17"x7" rims good tyres on 2, other 2 need replacing,
minor gutter rash but overallpretty good, (will not fit over large brake calipers) $600
#8 drivers door to suit 33 2dr, NO MIRROR, $80 post-35195-12720962536663_thumb.jpg
#9 Tail lights and centre garnish $200ono
#10 indicator/wiper lever assembly $40ono
#11 Brake booster $80ono (non abs)
#12 heater/aircon assembly $70ono
#13 engine bay wiring loom $150
#14 Digital climate control unit $50
#15 Dash wiring loom $50
#16 Accelerator pedal and cable $30ono
#17 boot and petrol cap cable $15
#18 seatbelts $50 set
#19 petrol cap cover $10
#20 steering column barrel and key $70
#21 Lower control Arms $125 each
#22 Front and Rear Hubs (Fronts pair $100 ono) (Rear pair $100 ono)
#23 Boot Lid and s2 Spoiler $150 ono incl gas struts and hinges
and lots of interior parts available, just ask.
all reasonable offers considered, as i need to move this gear.
cheers Ty
located in SA
Edited by sus 32
 Share
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
