I have a digital autowatch alarm on my car and apparently you can hook up all sorts of crap to it....
i have a spare button and i want to hook up an engine start onto it and on the other button which currently locks the doors and arms the alarm...i want it to put the windows up at the same time...
apparently this can all happen....but who do i get to do it??
or is it fairly simple...and i can do it myself....anyone else had this done?
by the way i know the start feature is illegal, but as i only drive on closed circuit roads and race tracks then it doesnt matter :P
https://www.sau.com.au/forums/topic/31939-car-alarm-help-auto-watch/
  • Replies 46
yeah fane, i know a guy who installs autowatch systems and he can wire up all the above that you mentioned. and more.
only downside he is in wangara. but WELL worth a nice 40 min drive to do it i rekon. Im not sure if u could do it yourself. i think its a lil more complex. but yeah he can make it so when alarm is activated the windows will go up. he can make it so when you start the car by remote it will put windows down etc. (if i remember right...)
but yeah.
pretty fancy stuff he can do with it... (he has his autowatch in his car hooked up to a mobile phone, so he can call his car and arm it over the phone, he has done many mad things with his alarm system.)
bad news, but apparently you can only get the start feature on an auto car. :)
i still want the windows to go up when i lock it tho i'll have to take it up and show the guy....i think autoworx put in the alarm i'll give them a ring aswell and ill give you an update cam... :P if anyone knows of anyone with the start feature on a manual let me know :)
thats what i thought... but he said nah you cant do it on a manual...and i said ohhh ok crap and he goes ohhh well we will have a look at it.... if it wasnt all the way in wangara it would be different...
i'll be able to find someone that will able to do it for me surely... :P
Woohoo! sucked in Manual boys :P sorry been waiting for something cool you can do with an auto car you cant do with a manual!
I need an alarm system put in mine ..... and i love buttons n gadgets etc .... so anybody know about how much these systems retail for?
just rang
PROCOM CAR AUDIO
1 Shields Crescent, Booragoon
Perth, Western Australia
Telephone (08) 9317-1302
Facsimile (08) 9330-3723
and they said the window lift hook up is $125, and he wont hook up the remote start because its illegal anyone know of any other places that may do it?
but at least i know where i can get the window lift hooked up... :P awesome!!
I saw a place called "Downunder Mufflers" on the corner of Scarb Bch Rd and Loftus St that has an Autowatch dealer sign out the front. These guys used to do a heap of compliancing work and specialise in imported cars apparently.
I was gonna take my Autowatch to em coz my central locking has never worked since I picked the car up and I never whinged at the time... silly me.
Red17
We at Action Alarms situated in Osborne Park are Autowatch dealers and can do the power window lift for you. $125 for the job is a very good price too, so I wouldn't want to better it.
Remote start is possible, but illegal! Is your car road registered? If not we might have a look at it.
Operating the alarm by mobile phone and or being called by your car if the system is triggered etc is also possible but not cheap. The pager option is a bit more affordable, but not as cool.
9242 4000 if you like,
Norbert
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
