Hi all,
I've been looking at a few interstate cars recently with the view of potentially getting one into Victoria.
Based on what I've read the authorities take a fairly dim view on top mount turbos here.
What's involved and how labour intensive is it to relocate a turbo from top mount to low mount location? It's an RB25DET with a top mount T3/4.
Obviously you'd need to confirm upfront that the turbo fits in the low mount location in the first place (not sure).
Other than that I've worked out that you'll need at least the following:
- exhaust manifold
- exhaust flange
- some new intercooler piping
Anything else? Can this be done without pulling the engine out, and how much work is involved?
Would it be easier to just throw in a stock RB25DET turbo & manifold?
Cheers
IMO it depends on what is used on the "T3/4", if it is using a large .7 A/R front comp housing then low mounting it still lets it be fairly obvious.
I was failed for having a GT30 low mounted, they worked it off the comp housing being far to large (compared to a factory one), and it was downhill from there (external gate was spotted next lol)
Can easily be done without engine out mate. Plenty of room to get in and around it all with just a trolley jack... a hoist does offer advantages!
IMO get a factory manifold and a hi-flow or something. It all bolts up, looks factory and bob's ya uncle... virtually undetectable 250rwkw.
Then sell off the high mount setup to someone else and recoup a bit of the cash.
Obviously the injectors/ECU will be picked, but they are easy to swap compared to a turbo and so on.
modified dump pipe.
new exhaust manifold
modified intercooler pipe
possibly modify the oil/water lines
modified intake pipe
You don't need to remove the engine it just takes time (or money if you are getting a work shop to do it)
If it was me and its a plain old T3/T4 i would just get a highflow stock turbo/manifold/etc and run that instead, same power but looks stock.
IMO if its a t3/t4, then check what turbo it actually is, sounds chinese, so you would be cheaper/better off buying a stocker and getting the turbo highflowed, exhaust front mount, stock airbox, clutch, nistune 250rwkw and almost undefectable
Thanks guys, that was mighty quick!
I'll have to confirm the specifics of the turbo.
Ok high-flowed stock items do indeed sound like a good replacement setup.
Cheers
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
