thanks heaps mate i have been doing that so hopefully it does bleed its self
also my temp is still sitting around 90degrees i was hoping that was because of an air pocket but if it does bleed the air and my temp is still the same yoiu reckon its worth geting it pressure flushed i have not had one done before and dont really no what is involed...
there are 2 other possible causes of a slightly higher temp.
1: thermostat is buggered. usually diagnosable by the car taking longer to warm up than it should
2: water pump is old and worn. when it's worn it doesn't pump as much water as it should. if the car hasn't had it's 100,000kms service then i would get it done. never trust the odometer reading on imports. i'd say that 90% of them aren't the actual kms the engine has done.
there is 1 other possible cause of higher engine temps but it is a bit more serious than those 2 so i left it off that list. the other possibility is a blown headgasket. i'd start with the above 2 first.
nah mate replaced the thermostat when i did the rad the car is due for its 100k service and is getting the water pump done at the same time ..
the car has no oil in the water or vice versa blows no smoke at all and does not burn oil so i dont think it the head gasket thanks heaps but
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
