Alright guys, we understand that not everyone has the same taste in rims so we'll do the following rims on pre-order prices and delivery in early August. This offer is until the end of May and on standard colours, optional colours are at extra cost. So why buy secondhand when you can buy new for the same price and at the offset you choose!!
18x9 Any offset you like, standard colour (optional colour available)
$3200
18x10 Any offset you like, standard colour (optional colour available)
$3300
18x11 Anyoffset you like, standard colour (optional colour available)
$3400
GTF
Chrome Silver
GTC
Spark Silver
GTM
Chrome Silver/Titanium Gunmetal
GTS
GTV
Titanium Gunmetal
https://www.sau.com.au/forums/topic/319482-volk-racing-gtc-gtm-gtf-gtv-gts/
can you do me a price on just a pair of 19 x 9.5 +17 gunmetal grey GTFs with polished lip.
Can you do an early order or an urgent airfreight to Brisbane?
can you email me at [email protected]
It takes 4 weeks from time of order to finished product, if you're happy with the time then we will get you a airfreight quote
Cheers
Ken
  • 3 months later...
Hi there,
Just wondering if you have any offers still available and also what sizes do the GTM;s come in?
Cheers
Dollar has droped so price will go up by $250
check here for sizing;
http://www.rayswheels.co.jp/2009/products/...p?code=VOLK_GTM
Would like to know the price of
Rays CE28N 18*10 into 4 wheels
Not sure about color, they normally come Bronze sort of color, I am after titanium silver
  • 2 months later...
  • 4 weeks later...
if i purchase a set of Volk GTS 18x10 +25, id need them posted to SA. how much will that set me back?
also whats the difference in 'Chrome Silver' and 'Mercury Silver' got any pics, its gonna be one of those colours but i havent seen them to compare and decide.
  • 4 weeks later...
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
