I'm about to make a one piece tailshaft for a 32 gtst with a gtr box (converted to rwd) and std 32 gtst diff that's making 500rwhp.
The GTR flange uses 75mm OD pipe( where its welded), while the 32 diff flange uses 65mm OD pipe (where it's welded).
What diameter pipe is best suited? any bigger than 3" pipe would have clearance issues.
How thick does the pipe have to be for this kind of power?
And whats the best method of stepping down the diameter of the pipe to suit the smaller R32 gtst diff flange?
A pic explains it clearer, currently using a shortened RB20 tailshaft.
https://www.sau.com.au/forums/topic/319526-one-piece-tailshaft/
^^ 2 pieces are generally smoother driving.
don't try and make a tailshaft yourself. people who do will charge like a wounded bull but if the balance isn't perfect then you're in for trouble. tailshaft turns at 4 x wheel speed (roughly).
Have a custom 3" Gibson single piece with extra heavy duty uni's in my 31. Standard 4.11 Auto diff, RB20DET with a 25 box. Havnt looked back, after killing 2 sets of uni's and centre bearing.
Get one made up for you. Cant remember how much it was, but its definately worth it.
Also had clearance issues once we dumped it. Had the chassis rails 80mm off the ground, & the driveshaft was eating the handbrake cable bracket. Had to raise the car up about 40-50mm. Still chews into the bracket occasionally with extra passanger weight..
Easy, slide the 65mm shaft into the 75mm shaft, simply find what gauge sheet steel you need to wrap around the 65mm so its a snug fit. Make sure the unis line up as factory (if it has unis) bead of weld and you are done. Make sure the 75mm shaft is cut to the right length so the weld is at the flange. then get it balanced by a shop.
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
