Hey guys, has anybody experienced this before?
This morning when I was about to start my Vee, the car lost all power to its systems and the alarm triggered.
There were no lights on the dash, the alarm was not responsive to my remote, the flashing immobliser light on the dash was not flashing (both stock and aftermarket), boot release not working, windows auto adjustment not working, etc etc. The alarm rang for a good 10 minutes before it died out.
Any thoughts or suggestions on what I should do? A fuse I can check perhaps, or need to have the car towed to an auto electrician / immobliser fitter?
Thanks.
https://www.sau.com.au/forums/topic/319527-blown-fuse-or-something-worse/
Sounds like a flat bettery to me: the alarm should have a backup if it's decent, which would explain why nothing but the alarm worked...
I had a similar incident: got back to my car to find the brakelights strobing like crazy: tried to start it, and nothing, except I could hear a relay going crazy (clicking)... Turned out I'd switched the foglights on by accident when I indicated to park, and they stayed on. A quick jump start and a short drive, and it was all sorted.
Maybe have your alternator checked?
thanks for your posts guys. i too am hoping it's a weak battery esp considering that it was cold this morning in Perth.
but the car started without fuss yesterday. when i inserted the key this morning everything lit up as it normally does before the power cut happened and the alarm sounded. yes it's probably the depleated battery for the alarm that stopped the siren after about 10 mins.
lol @ headlights not turning off when battery is weak!
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
