Im sure the topic has been hashed over several times......
Just got my policy renewal today and nearly fell over cause in the 2 yrs ive had my car the policy has gone up over $400 bucks! And ive never claimed or had any driving offences what so ever!
Im insured with Lumley Special Vehicles.
2008 policy was $1000
2009 policy was $1250 ish
today $1440
Can any of you other 34 drivers or anyone in general tell me who you insure with and approx how much, cause this is getting out of hand the policy going up by a couple of hundred every year!
Thanks Donna
https://www.sau.com.au/forums/topic/319560-insurance/
  • Replies 46
today $1440
Thanks Donna
mine has gone down every year, time for a new insurer me thinks
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5218582
today $1440
Thanks Donna
How old are you?
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5218627
30 in a couple of months, so im no teeny-bopper! lol lol
Seriously change your insurer. I am with Shannons on an agreed value deal for 6/700 a year (cant recall excactly without looking at the policy)
You are getting right royally rogered atm.
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5218649
been making some inquiries ......
shannons about $800 with $500 excess
just car $712 with $1500 excess
so ill definetly be taking one of those instead i think .....
when i called LSV i got the same bla bla bla story i did last year, shannons has an agreed value and with just car its a few grand under that.
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5218681
Even though Suncorp owns Just Car and Shannons have you tried them for a quote too? R33 GTST with Just Car was $1400 at 25 with perfect history in Toowoomba. Suncorp quoted $690 at the time iirc
I find that hard to believe. I've rung Shannon and Suncorp just to check recently and Shannon doesnt insure a daily car and Suncorp was like 2k. I'm sticking with Just Car for now at around 900 premium and 1.5k excess.
PS: Daily Car = one and only car regardless of how many times you drive a week. The other condition to fulfil if you have 2 cars is you can only drive the insured car for 2 or 3times a week if I remembered correctly.
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5222000
I believe AAMI owns just cars, not suncorp. But they won't insure anything modified/import, they'll just direct you to just cars.
Just cars however will insure anything, but they will charge more than AAMI. It was about half as much to insure my shitbox XF with AAMI than it was with just cars
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5222137
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
