Hey tommmo hows the motor going its been a few weeks since last update did she start up alright? Keen to hear the news.
well the good news is, the car has got a sweet running heart again!
the bad news is.. ive been sooo busy over the last 2 weeks, i've only had time to drive it home... thats it!! :unsure:
keen to take it out this sunday, and then due for a proper tune up friday week
got home after work last night and just couldnt help myself.. picked up the keys and went for a nice drive to hahndorf
I must say Paul has done a fantastic job :3some: its very quiet and smooth..... until I put my foot down and you hear its growl via the exhaust.
I had the biggest, cheesiest grin on my face driving back down the hill.
Cannot wait until the tune next week!!!
Coming home along portrush rd, I saw headlights speeding towards me in my rearview, I automatically thought "great.. gonna get pulled over and harrased by the po-po first night out" turned out to be an fpv, he pulled up next to me.. revving whilst driving side by side, trying to get my attention.
I didn't respond, douche then floored it, lost traction and almost lost it.. friggin idiot! Where's the police when you need them?
The popo are where you don't need them and when you need them they take 30mins to an hour
On the other note. Good to hear that your car is back up and running again mate :D
picked my r32 up to start running-in last thursday, only driven it home so far
but was amazed at how strong the fresh Rb26 engine felt.
definately a heap more power than my Rb25
even with only steel-wheel rebuilt turbo's the power/punch is pretty brutal.
hoping to get out for a few days driving (running-in) soon. then can get back to boostworx for the tune
  • 3 weeks later...
  • 3 weeks later...
Updates?
Few things came up (not car related), hasn't been tuned yet.
Its at the workshop:
Injectors installed
Fuel Pump installed
AFMs installed
PFC installed
Ready to rock'n'roll!!
tuner is away until friday though, will hopefully have a result then.
Edited by Tommmo
Not entirely happy with the tune.. Terrible on cold starts, need to turn ignition over twice before it starts, when it does, timing is all retarded and drives sluggish.
A lot better when it warms up, but still a bit hesitant when just cruising along at 2500rpm. Not sure if this has something to do with the larger injectors? When foot is 3/4 or flat on the throttle, it does pull very smoothly.
I'd like to see final boost setting around 22psi and lean it out a bit more, noticed it's chewing through petrol pretty quickly at the moment!
John does know what he's doing..
you're right.... i've been going there for a few years now, he's always been good.
Might give him another crack at it, just give him a de-brief of how its responding on the road etc
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
