  • Replies 117
Posted Images
I wouldnt call it a complete waste of time.
Pretty sure Full Race added those same members to their S14 too. I guess they know what theyre doing too.
I like the sound of this mod though.
Been contemplating correcting roll centres for a while now. This seems fairly easy.
Thanks for the write-up.
Should I change anything else then because if I just changed the subframe and left everything else the same wouldnt my back wheels turn whenever they felt like it (sorry not sure what theyre called on the back, knuckles? Hub?)
Edited by 30edR32
FFS dont put a s14 cradle in a 32. what a waste of time. get a non-hicas s13 (w. r200 4 bolt pattern) subframe buy some riser bushes foam fill the frame and put it in. Will all bolt up and will correct your suspension geomatry, no point going s14.
get a set of rear toe arms to replace that hicas rack.
40edr32, if your in brisbane PM me ill take u under my wing and help u out :P
Edited by 32_Dave
hell you can use anything. the whole gain is from raising the subframe and using a stiffer bush. I have a mate who has gont the right tight arsed option and cut the top off the stock nissan bushes til its flush with frame and then welded a flat steel washer to the frame and the steel crush tube. effectivly locking it. then bolting it all back up.
works just as well. but too dodgy for my liking haha
thats just what the japanese guys do for a quick fix, was on a doriten video
40edr32, if your in brisbane PM me ill take u under my wing and help u out :)
Ha thanks Dave, that sounds much easier and quicker.. Unfortunately I'm not in Brisbane, although I wish I was. Could you still explain this too me a bit? Riser bushes as on the LCA's or something else completely? And foam fill the frame.. never even heard of that
the riser bush see pic 1 bellow. replaces the factory subframe bush see pic 2 bellow. in doing this you raise the entire subframe approx 0.5-1" higher. how this works is the shape of the riser bush, one end has a shafered edge where the standard washer and bolt go see pic 3 and the other is dead flat making the top lip of the subframe sit flush on the cars rails, see pic 4. Having the subframe sitting higher will correct all the suspension geomatry from being like this \ / on a low car to this _ _ see pic 5 making the suspension work properly how it was designed. Replacing all the factory bushes in the rear end to urethane or even sepherical bearings. (most people just use urethane) Onto foam filling the subframe, you use a marine grade which sets extremely hard, this makes the subframe basically 1 sold piece reducing and movment within the frame itself. It is a 2 part foam that you inject into all the hollow sections of the frame.
Next is correcting the same thing for the front end. You drill your front Lower Control arm (LCA) upwards. See pic 6 Then the only thing left to correct is your tie rods, simply buying new tierod ends can fix this. See pic 7
picture 1:
Picture 2:
Picture 3:
Picture 4:
Picture 5:
Picture 6:
Picture 7:
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
