Gday all,
I am selling my A31 Cefiro as I can't afford to finish building it into what I want as other commitments in life don't allow time.
Engine: RB20DET
Turbo: stock
Intercooler is stock but car comes with front mount. I had the front mount hooked up but put old stock one on to pass roady.
Seats are stock but comes with R32 drivers seat
Has a Uras looking kit though only front bar is on so far side skirts and rear bar are waiting to be connected.
Diff is stock though comes with R180 locker
Brand new BC Racing TA coilovers
Just Jap adjustable castor rods
Boost gauge
Boost controller
KKRacing Steering wheel
2.5' exhaust is the one I got it with and haven't let her breath with the 3' yet sadly
Enkei Racing Black 17's on the front
16's on the back
Plenty of spares that come with the car
Spare radiator shroud
3' Nismo rear muffler
I am willing to sell parts separately that aren’t on the car but will come with it.
Looking for $8000 ono
Cheers.
https://www.sau.com.au/forums/topic/319589-a31-cefiro-going-cheap/
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
interested in a series 4 rx7 with s5 mild port motor turbo?
if your cars rego'd i'll chuck in some cash
got a number? where abouts r u from?
http://www.skylinesaustralia.com/forums/Fc...-M-t336053.html
Edited by driftn7
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
