Was it as responsive at stockie? NO.
i've been in it stock. and hell yeah its responsive :blink:
BACK ON TOPIC.
car look's nice and neat, but with a big red pod hanging out next to some Chrome piping, you'll get raped, not to mention braided lines. just stating the obvious :P
looks awesome though, and with that power figure will be awesome to to drive, what have you got planned for when you loose your license in 7months haha
lmaooo nicee i wish i had my car when i lost my license
i lost my license for 1 Yr and 3 months, its not like i stoped driving lmao they didnt catch me
Smart....
dam i dont think i could go over a year without my licence 6 months was enough . but if i do ever loose it again i will most likley put a 2.5 lt engine in the 32 . one of my mates did it with a bigger turbo and external gate set up , it was simply amazing. the power and the noise was awesome . even if i dont have to be forced off the rds i will eventually do it , just time and money i guess.
thanx for the feedback , ill bring the car to some SAU meets soon . my old man will be driving it to Vic Imports Club meet on the sun 16th may for me, then i get my licence back the following sunday .
CANT WAIT !
very nice.
Is the HKS GTRS direct bolt-on to the dump? When does full boost come in?
Also where you get those steel hoses for the catchcan
imo the airpod isnt in the best place. One bad downpour and its gonna be soaked.
i get full boost (18psi) at 4000rpm or maybe just below that in the gts4. GT-RS is the best turbo for the RB20, get one Pat you know you want one! :3some:
that said, i'm pretty happy with the HKS2510 on the gtst :) response almost like stock.....
Douche, that's what im trying to tell you, the obvious..
well obviously i already know that the standard turbo in more responsive
however what i was saying was Matt's car isnt that laggy, cosidering that amount of work done, hench why its off-tap
Well if you go back to my initial post and you will realise that i compared the gt35 to standard turbo...Thats all i was saying...I probably only said it 'cos i hate laggy tubos, probably because i had one.... 4000rpm full boost... Normal driving, going up the westgate bridge, you need to down gear, turbo wouldnt boost at all under 3k. But that all depends on set up your running of course.
Actually... you never went in my car so you wouldn't know. It had a shitload of response down low, it was just as responsive as a stock turbo but with more power everywhere. More flow, more boost, less exhaust restriction + good tuning. My point is, GT35's are not laggy if you run the right setup with a built engine and all the goodies. If you are comparing a stock turbo on a stock engine to a GT35 turbo on a stock engine, then you're just stating the obvious.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
