i don't think they had obvious markings on them mate.
Well considering the three most common choices of cams in a RB25 heads are:
1. Stock cams
2. Poncams
3. HKS cams
Then you should be able to tell (or post up some detailed pictures and I can tell you since I have had them all) which one of those three they are or if they look like something different.
Edited by PM-R33
He did mention he already has Poncams, installing an adjustable exhaust cam gear is silly, the Poncams have been already engineered for good mid response.
- Adjust your gain setting so the boost comes earlier
- post up your timing map, maybe your tuner was lazy and only tuned from columns 12+ to get you your kW figure and nothing else, you be amazed how many lazy tuners there are out there, that just subtract 5 degrees from the map from rows 15+ and then do a map trace and only tune on full throttle on the dyno
To be 100% sure they are aftermarket cams, pull camcovers off and measure the height of lobe and base circle diameter with vernier clamp.
Aftermarket cams should increase mid to high hp, torque. Can create a bow look to dynograph at lower rpms when cams have enough duration, lift. Also aggressive enough cams should create a lumpy idle (or stock / Tomei cams that had camgears adjusted). Tomei Poncams probably would have a smooth idle and look similar to stock cams, unless you adjust the camgears to make idle lump.
This dynograph shows what happens when intake, exhaust cams are adjusted on RB20DET (should be similar with RB25DET) -
http://www.uniqueautosports.com/Dyno/yx32gtstdyno.gif
Not to be rude but is blatantly clear that the ramp rate was changed for the both cam gear changed run to make it look better.... so the graph is pointless and misleading.
I agree with Ash. I would be looking at the boost controller settings. Most hiflows I have seen go straight to say 18psi, hold 18psi and then drop off at the end. Yours is 16psi at 3500rpm, 17psi at 4500rpm. It just gets over 17psi for a short time so I would hardly say its running 18psi.
Set it up to go straight to 18psi or even a bit higher and then leave it drop off to 16psi near redline. Especially in the lower revs it doesnt hurt to have a bit of extra boost to get going.
I dont think its an exhaust restriction because it still makes good top end power.
i wound the gain up from 19% to 30% (the max setting is 35%), and the start gain from 15psi to 15.5psi. it didnt make any difference as far as the seat of my pants is concerned. i still think its lacking power below 5000rpm.
will look at the other issues.
A whole 0.5psi :(
I know its a bit worrying but the tune should account for a bit more boost. if you are really worried try on a dyno. I would try 17psi so it flattens out to 18psi. will still be the same boost up top.
Edited by Harey
A whole 0.5psi :(
im not worried about running more boost. id happily run 25psi if it made more powah.
the set gain of 15/15.5 psi setting is when the ebc starts to regulate boost, according to the greddy manual. and they recommend setting this for 2-3 psi below desired pressure. yeah i can wind it up to maybe 17 or such, ill try it tomorrow.
would 1 psi at 3500-4500 really make much difference? cant hurt i guess!
    • Sorry the pictures suck. So hard to get camera and light in there
    • One of the first jobs with the E39 is making sure the tailgate stays up. In BMW fashion they made a little cavity under the roof to hide the dampers rather than putting them down the side like everybody else.  As you can see I have these little cavities that house the dampers. When I cleared one out and vacuumed as much crap as I could out of it I noticed a fair bit of rust. The cavity is bone dry, even after all that rain we had only a few days ago so I'm assuming that whatever allowed the moisture in is fixed but I'd like to treat the rust in there.  I was thinking of just blasting it full of rust converter but I didn't know if this would be beneficial considering I can't actually get in there to prep anything.  Maybe there's a better product?  Thanks guys
    • Had a few skylines over the years anyway bought this a few years ago for skidz i think it’s been around these traps for a while anyway I plan to thrash and trash and I assume it’s going to send me broke good times
    • The stock boost solenoid is just a valve. Power it and it is open. Unpowered, it is closed. When it is closed, there is no boost bleed out through the solenoid back to the inlet. The wastegate sees all the boost pressure, thus you get the wastegate's spring pressure as your boost pressure. 5 psi. When it is open, it lets some boost escape. This causes the static (boost) pressure in the line to the wastegate to be lower than the pressure in the intercooler pipe. There is probably a small restrictor in the solenoid or one of its lines to limit the flow rate of the escaping air, which limits how far the static pressure can fall, which limits the extra boost. The boost has to climb above the original/wastegate setpoint until the wastegate sees 5 psi. You get 7 psi in the intercooler pipework. A manual boost controller is exactly the same setup, just without the ability to change it on-off. It's always set to whatever you set it to. There is a small leak from the boost controller. The more you screw the adjuster in, the more it leaks, the lower the pressure seen at the wastegate and the higher the boost will be. So, yes, your diagrams are correct.
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
