Very, Very Unfortunate News...
GoldZilla
very sad news. sorry to hear of two young guys loosing their lives. anything can happen in a car at any time and it's not necessarily a reflection on them or us that tragedies like this happen. it can and does happen to people all the time on our roads.
my condolences to their families and friends, it's so sad to see another's life cut short.
  • Replies 159
The funeral is going to be on
Friday 14th, 1pm at St bernadette's Parish, Lalor Park.
Burial at Castlebrook
Followed by the wake at Outback Steakhouse.
You are all most welcome, Im sure Gerard would love you all to be there and I would find it comforting.
x.o
Darn, I can't get out of work to make the funeral. Approx. what time is the wake? I'd like to try to make that.
Thanks.
Thanks.
If I can help it it will be going long into the night
10 pm sounds like a good bedtime :3some:
HI Everyone,
Details of Tom's funeral -
Monday 17th May. 10.00 am
Macquarie Crematorium - Delhi Rd
Magnolia Chapel.
Macquarie Park Cemetery and Crematorium - Corner Delhi and Plassey Roads - North Ryde
A celebration of Tom's life, followed by BEER and PIZZA at the Prescott House. - Please speak with me for adress details if you wish to attend.
Please don't bring flowers, but if everyone could bring something that reminded you of Tom and the wonderful life he lead.
Live. Love. Race.
icon_sad.gif tragic stuff. Only found out today. I remember from Gerard's posts and his responses to some of mine it was clear he was a man passionate about his cars and engineering. He was very quick at the track in an mx too.
Good to see the SAU and cartalk communities responding so thoughtfully.
10 pm sounds like a good bedtime :P
HI Everyone,
Magnolia Chapel.
Live. Love. Race.
Hey sheri...Me and Kate will be there on monday.
Just returned home from Nicks.
Alex it was a wonderful service and 'im sure Gerard would of been proud..
Once again i'm very sorry for your loss but you held yourself together beautifully on a very emotional day.
Although I didn't know him as well as most of you it was good to pay my respects to the first person that welcomed me to the world of racing..
I wish I had a chance to get to know him more then what I did on the occasions we spoke.
Thanks to all that attending and to all that lent their support.
It was a beautiful day for a very beautful guy.
I am so happy with how everything went, he was spoilt the whole time.
I doubt anyone has had a more awesome coffin..!
Mazdaspeed herro kitteh is now with him forever (heheheh and he thought he could get rid of it by taking it off the car =P)
Thanks again..!
much love
x.o
Indeed it was an amazing day. I want to thank all thoes from SAU who came to the funeral on friday and showed there support including our club pres Neil and the exec Steve and Duncan. Its the way the club cares for its members that sets us apart from many other clubs im definatly proud to be a member. See everyone at Toms tomorrow.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
