  • Replies 159
Got to work this morning and saw the news. I thought that car and wheels looked way too familiar, and had a bad feeling it was.
Only saw these guys early last night too, what a waste.
My sincere condolences to the families as well. Couple of great blokes.
I now have known way too many people now that have lost their life on the road, even one is too many.
Take it easy guys, no one is immortal.
OMG i saw this today when i got to work. Thought it was such a tradgic accident. Makes it even worse to be someone you clearly all have so much respect for.
Condolences to all friends, family, and everyone else who knew the guys. I unfortunately did not get the pleasure, but i can see their memories will live on through the forum.
And props to you Nick, for doing the honourable thing, and making a thread for this.
Edited by Black Widow
terrible news, its also upsetting to see the media always jumps to the street racer scenario in circumstances like this.
http://news.ninemsn.com.au/national/104945...way-truck-crash
Pretty sure I met these blokes at the meet a few weeks ago. I saw the news this morning and had a feeling that I'd seen the car somewhere.
Even though I had only met them briefly, it's still a massive shock.
It's sad when someone is killed in a crash, but it's even worse when a passenger is innocently taken too.
RIP boys.
Two awesome guys, last thing anyone wants to hear. My condolences to the families during this tragic time. Alex it's safe to say that you have all of our support during these tough times.
RIP guys
Absolute scumbags. Just shows nothing is sacred for the media. They don't even know the facts of the situation, so much for journalistic integrity if there is such a thing.
Thank you guys for your support, I had organised a Track day for Gerards Birthday on the 20th of May.
This is still going ahead as a tribute to both Tom and Gerard, they were amazing guys and no words can express how much they are loved and will be missed.
It is a speed off the streets day, so if you were friends with either of the boys or wish to pay your respects, you are more than welcome to attend.
I will pass on all your kind words to the families involved.
It is a sad day indeed, but any words of support are comforting.
x.o
I was going to make comment to this in my post but wasn't sure if it was appropriate of me to given the circumstances.
My condolences to all affected by this.
As Nick said, the media will likely be trawling forums looking for anything they can use and are already painting negative pictures about the accident;
  Quote
Nine News understands that text messages are sent out weekly to about 20 people organising meets on the highway.
source
I'm so sorry that this has happened. We've lost a lot of good people over the years in this club.
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
