Hey ppls.
I have searched the web and the forums and I can only find reference to the USE Apexi site for the english instructions for the S-AFC 2
The download works from Apexi, but it has errors so there is 64 pages of nothing.
Does anybody have this on file that definently works??
All help appreciated.
BASS OUT
https://www.sau.com.au/forums/topic/31966-apexi-s-afc-2-english-instructions/
I have a working copy. 1.7mb pdf. loads fine in my acrobat. but you probably do need language plugins. Not sure if i do or not, i do get an error about a missing plugin when its loads, but i can still read it.
Okay,
I tried downloading the new Acrobat 6.0 reader and installing the Japanese language fonts, but still to no avail.
it says
"There was an error processing this page. The encoding (CMap) specified by a font is missing or currupted.
Does anybody have a version that DEFINENTY works from this and could they e-mail it to me.
Its the S-AFC 2 manual and wiring diagram.
[email protected]
thanks
BASS OUT
Other manuals on the site work, such as the power F.C one, but the S-AFC2 one doesn't.
Hey Bass Junky, i downloaded the japanese lang. pack from http://www.adobe.com/products/acrobat/acrr...anfontpack.html for acrobat 6 and it worked fine...
Ah HA!
I have it sorted.
My adobe was automatically opening an old version of Acrobat reader, and therefore one not updated with the new language pack.
Problem solved and manual printed out!
Thanks for your help guys
BASS OUT
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
