R32 Gtst Power Steering Pump, Rack And Security System
I bought the car like this, but the previous owner installed a on/off switch on the dash to turn on the AC compressor. I believe this switch is wired to the engine bays fuse panel. When i switch the AC compressor on, i feel it dragging the engine and it makes a grinding noise. My question is, should i have the AC compressor rebuilt? is that a possibility? or should i buy a new one?
By TurboTapin · Posted
Anytime I still have a small amount of new oil left after an oil change on one of our cars, I dump it into a container. It's a concoction of different weights that I like to believe evens out to a 10W-30. I do an oil change every year on both my tractor and mower using that oil. Mower is at least 12 years old, and my tractor is about 5 and sat 2 weeks under 10 feet of water. Both still run great! -
Depends on your hp target/if you want to max your turbo, in my experience a twin scroll housing will spool like a much smaller single scroll housing, with little to no loss of peak hp. If you want quickest spool, Pulsar sells 0.85 t4 ts housing for g30 and g35 at less than half price of Garrett's housing.
Ring & pinions are not interchangeable between long and short nose. Pinion is longer in a long nose diff. Cheers. -
I believe it is a r33 throttle body form any rb25det that will work, so I ordered one of these up, we will see.
