Atr43ss-2 Prototype Initial Tune 250rwkws 18psi<2500rpm, Stupidly Responsive
  • Replies 118
Posted Images
Looks like the turbo could be out of flow. Given there is a 20rwkw drop from 5000-5700rpm :)
I'm guessing the results drop severly hard after 5700rpm? That is why run stopped?
Were there any issues with boost control or just compressor running out of puff/flow?
for what it's worth the stock turbo looks like;
160km/h = 5714rpm = 195rwkw
170km/h = 6074rpm = 189rwkw
the stock turbo seems to peak at 5700rpm ish
and the prototype seems to peak at 5000rpm ish
this is based on my stock turbo tune
neither is right or wrong just offering data
i think a 33 GTST with that powerband would be pretty sweet on the street
its a good 50rwkw ahead everywhere in the power band so it should be shit hot
Looks like a tad bigger would be far better suited to the motor though. Enough to get it flattening off around the 6500 mark would be far better.
Impressive results nonetheless.
i drove this car today.. it is an ANIMAL of a street car! absolutely in love with the response... congrats Stao :wub:
i didn't really rev it out to redline, probably only about 5.5k, so i didn't get to experience the drop off in power.. still heaps of fun though
I'm modeling a turbine housing that has external gate ports in and out to have an external gate replacing the current actuator setup. So boost control issues is going to be history. shortly.
Looks like the turbo could be out of flow. Given there is a 20rwkw drop from 5000-5700rpm :wub:
looks to be like the compressor has plenty of puff and the exhaust housing is out of flow..
No NO. Please do not cancel your trip for this turbo. There are still few things I'm doing to get it perfect. I will make it commercially available when ready.
With the drop it could be if the housing's maxed, external gate should solve abit of that issue. We see what happens.
I too can attest for this turbo, Stao let me take it for a spin on saturday. Car is super responsive, 1st and 2nd gear are just insane and third pulls very nicely but looses the insanity slightly. But by then your doing over any legal speed limit anyway. So if its response your after I would definitely recommend this.
Thanks again for the drive!
Would I be right in saying this is a HKS GTRS replacement?
I dont believe so... needs to touch 280-290rwkw and maintain its topend while still beeing internal gate to get up on same level, i'd more so go with its a 2530 replacement considering the figures and much better response...
I would say it looks a close thing with a HKS GT-RS although it is coming on quite a bit earlier.
Getting a HKS GT-RS to 280-290rwkw is stretch with very few getting there from what I have seen.
250-260rwkw is probably a more realistic expectation.
^ yeah but holding to 7500-8000rpm is also looking like a problem.
Although given a lot of people want bolt-on replacement for "stealth", not sure going to external gate is going help sales as such :P
agreed, the exhaust housing to me really seems to be the bottleneck in the setup.
My GT-RS is managing 253rwkw at only 14psi (i know different dynos vary, but thats on the godzilla motorsports one).
So im hoping its capable of 270rwkw-280rwkw with 20psi through it.
This turbo looks alright.
I have never seen one make 280-290 rwkw on a stock rb25.
Same as I dont think I have seen a 2530 make 250rwkw...
seems like this thing would drive like a V8 haha.
i think its near impossible to have a turbo be as responsive as this and make decent top end.
the small rear housing will refuse to hold high boost at high rpm, therefore peak power at 5,000 odd.
but peaking at 5,000 i think seems a waste of the revving nature of the RB.
truly a street turbo; lots a power in the early rev range, but with no top end.
would be interesting to see how you go with boost control.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
