Atr43ss-2 Prototype Initial Tune 250rwkws 18psi<2500rpm, Stupidly Responsive
  • Replies 118
Posted Images
Looks like the turbo could be out of flow. Given there is a 20rwkw drop from 5000-5700rpm :)
I'm guessing the results drop severly hard after 5700rpm? That is why run stopped?
Were there any issues with boost control or just compressor running out of puff/flow?
for what it's worth the stock turbo looks like;
160km/h = 5714rpm = 195rwkw
170km/h = 6074rpm = 189rwkw
the stock turbo seems to peak at 5700rpm ish
and the prototype seems to peak at 5000rpm ish
this is based on my stock turbo tune
neither is right or wrong just offering data
i think a 33 GTST with that powerband would be pretty sweet on the street
its a good 50rwkw ahead everywhere in the power band so it should be shit hot
Looks like a tad bigger would be far better suited to the motor though. Enough to get it flattening off around the 6500 mark would be far better.
Impressive results nonetheless.
i drove this car today.. it is an ANIMAL of a street car! absolutely in love with the response... congrats Stao :wub:
i didn't really rev it out to redline, probably only about 5.5k, so i didn't get to experience the drop off in power.. still heaps of fun though
I'm modeling a turbine housing that has external gate ports in and out to have an external gate replacing the current actuator setup. So boost control issues is going to be history. shortly.
Looks like the turbo could be out of flow. Given there is a 20rwkw drop from 5000-5700rpm :wub:
looks to be like the compressor has plenty of puff and the exhaust housing is out of flow..
No NO. Please do not cancel your trip for this turbo. There are still few things I'm doing to get it perfect. I will make it commercially available when ready.
With the drop it could be if the housing's maxed, external gate should solve abit of that issue. We see what happens.
I too can attest for this turbo, Stao let me take it for a spin on saturday. Car is super responsive, 1st and 2nd gear are just insane and third pulls very nicely but looses the insanity slightly. But by then your doing over any legal speed limit anyway. So if its response your after I would definitely recommend this.
Thanks again for the drive!
Would I be right in saying this is a HKS GTRS replacement?
I dont believe so... needs to touch 280-290rwkw and maintain its topend while still beeing internal gate to get up on same level, i'd more so go with its a 2530 replacement considering the figures and much better response...
I would say it looks a close thing with a HKS GT-RS although it is coming on quite a bit earlier.
Getting a HKS GT-RS to 280-290rwkw is stretch with very few getting there from what I have seen.
250-260rwkw is probably a more realistic expectation.
^ yeah but holding to 7500-8000rpm is also looking like a problem.
Although given a lot of people want bolt-on replacement for "stealth", not sure going to external gate is going help sales as such :P
agreed, the exhaust housing to me really seems to be the bottleneck in the setup.
My GT-RS is managing 253rwkw at only 14psi (i know different dynos vary, but thats on the godzilla motorsports one).
So im hoping its capable of 270rwkw-280rwkw with 20psi through it.
This turbo looks alright.
I have never seen one make 280-290 rwkw on a stock rb25.
Same as I dont think I have seen a 2530 make 250rwkw...
seems like this thing would drive like a V8 haha.
i think its near impossible to have a turbo be as responsive as this and make decent top end.
the small rear housing will refuse to hold high boost at high rpm, therefore peak power at 5,000 odd.
but peaking at 5,000 i think seems a waste of the revving nature of the RB.
truly a street turbo; lots a power in the early rev range, but with no top end.
would be interesting to see how you go with boost control.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
