Nissan C33 Laurel Rb25det
Item Summary: nissan c33 laurel rb25det
Condition: Used
Reason for Selling: want cash
Asking Price: 11000
Delivery Methods: PickUp
Contact Info:
Extra Information:
Item Summary: nissan laurel 1992 c33
Condition: Used
price:11,000 o.n.o
Contact Info: pm me or cal 0406039905
Extra Information:
hey guys sellin my 1992 c33 laurel
1992 c33 laurel
rb25det.. not to sure on ks fresh conversion.
5spd manual
short shifter
exedy 5 puc botton clutch
jjr fuel reg
spitfire coilpacks
gtr fmic
3inch exhaust with drift twin pipes
500hp
k sport coilovers front and rear. 10kg fronts 8kg rears
REAR
camber arms
toe rods
traction rods
front caster arms
extra lock spacers
cusco strut braces front and rear
blits boost oil pressure water temp gauges
deep dish steering wheel
r32 front seats
hand brake drift button
selling with silver metallic paint
getting this painted in next few weeks . then if ive got enough cash getting a tune when my wolf 3d is fixed and goin for 300hp.
swap for stagea?
link as follows
http://www.carsales.com.au/all-cars/privat...&__Qpb=true
its a long way away,but we can work something out
couple questions
-is it rego'd with the rb25det?
-will it pass a roadworthy? super strict in SA thats all
thanks,will sms you in the morning mate
rodney
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
